[GRASS-dev] [GRASS GIS] #560: WinGRASS not deleting temp ppm files from map display
GRASS GIS trac at osgeo.org
Fri May 3 19:42:23 PDT 2013
 Reporter:  isaacullah                  |       Owner:  grass-dev@…
     Type:  defect                      |      Status:  new
 Priority:  critical                    |   Milestone:  6.4.3
Component:  Display                     |     Version:  6.4.0 RCs
 Keywords:  v.digit ppm temp, wingrass  |    Platform:  MSWindows XP
      Cpu:  x86-32                      |
Comment(by hamish):
 just tested, it's still an issue.
 the gui should be cleaning up after itself, but perhaps the wxGUI temp
 .ppm, .pgm, and 0 byte no-extension versions of the same files could at
 least be placed in a \grass-wxgui subdir of \Temp\, so at least they are
 consolidated and easier to manually bulk clean up if grass is shutdown
 uncleanly?
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/560#comment:17>
