[GRASS-dev] [GRASS GIS] #1959: wingrass wx carto composer: Image causes traceback
GRASS GIS trac at osgeo.org
Sat May 4 02:29:41 PDT 2013
 Reporter:  hamish                 |       Owner:  grass-dev@…
     Type:  defect                 |      Status:  new
 Priority:  major                  |   Milestone:  6.4.3
Component:  wxGUI                  |     Version:  svn-develbranch6
 Keywords:  cartographic composer  |    Platform:  MSWindows XP
      Cpu:  x86-32                 |
 testing latest 6.5svn nightly wingrass build.
 If you open the wxGUI cartographic composer and pick 'add map element'
 then "Image" (better to call that 'map decorations'?; better to make menu
 item "EPS Image" than lead user down a false path?) you get the following
 PyAssertionError in the wxGUI command console:
   File "C:\Program Files\GRASS GIS 6.5.svn\Python27\lib
 \site-packages\wx-2.8-msw-
 unicode\wx\lib\filebrowsebutton.py", line 140, in OnChanged
 self.changeCallback(evt)
   File "c:\Program Files\GRASS GIS
 6.5.svn\etc\wxpython\psmap\dialogs.py", line 4272, in
 OnDirChanged
 self.OnImageSelectionChanged(None)
 6.5.svn\etc\wxpython\psmap\dialogs.py", line 4304, in
 self.ClearPreview()
 6.5.svn\etc\wxpython\psmap\dialogs.py", line 4386, in
 ClearPreview
 mask = wx.Mask(buffer, wx.WHITE)
 \site-packages\wx-2.8-msw-unicode\wx\_gdi.py", line 1212, in
 __init__
 _gdi_.Mask_swiginit(self,_gdi_.new_Mask(*args, **kwargs))
 wx._core
 PyAssertionError
 C++ assertion "!bitmap.GetSelectedInto()" failed at
 ..\..\src\msw\bitmap.cpp(1509) in wxMask::Create(): bitmap
 can't be selected in another DC
 6.5.svn\etc\wxpython\psmap\frame.py", line 663, in
 OnAddImage
 dlg = ImageDialog(self, id = id, settings =
 self.instruction)
 6.5.svn\etc\wxpython\psmap\dialogs.py", line 4093, in
 __init__
 self.OnDirChanged(None)
 OnDirChanged
 self.ClearPreview()
 ClearPreview
 __init__
 wx._core
 PyAssertionError
 and no image selection gui window. On my linux it works.
 thanks,
 Hamish
 (trac logging itself out every 5 minutes! argh)
Ticket URL: <https://trac.osgeo.org/grass/ticket/1959>
