[GRASS-dev] [GRASS GIS] #1961: wxNVIZ: error if no raster map selected
GRASS GIS trac at osgeo.org
Sat May 4 02:51:11 PDT 2013
 Reporter:  hamish  |       Owner:  grass-dev@…
     Type:  defect  |      Status:  new
 Priority:  major   |   Milestone:  6.4.3
Component:  wxGUI   |     Version:  svn-develbranch6
 Keywords:  wxnviz  |    Platform:  All
      Cpu:  x86-64  |
 testing wxNVIZ in latest 6.5svn, I get an error and 100% CPU use if I
 select '3D view' in the map display window with just a vector map
 selected. (also tried with a 3D vector map, same thing) happens both on my
 linux and Wingrass-VM. It's recoverable once you switch back to '2D view'
 mode.
 one possible solution is in the case of no raster tell nviz to create a
 new constant surface at z=0 with 50% transparency. (or at least that's the
 trick with tcl/tk nviz + no raster to drape things on)
 traceback from wxgui module output window:
 Starting 3D view mode...
 Vector map <roads at PERMANENT> loaded (746 features)
   File "/home/hamish/src/grass/svn/grass65/dist.x86_64
 -unknown-linux-gnu/etc/wxpython/nviz/mapwindow.py", line
 366, in OnPaint
 self.DoPaint()
 383, in DoPaint
 self.lmgr.nviz.UpdatePage('view')
 -unknown-linux-gnu/etc/wxpython/nviz/tools.py", line 4233,
 in UpdatePage
 hmin,hmax)
   File "/usr/lib64/python2.6/dist-
 packages/wx-2.8-gtk2-unicode/wx/_controls.py", line 2692, in
 SetRange
 return _controls_.Slider_SetRange(*args, **kwargs)
 OverflowError
 long int too large to convert to int
 366, in OnPaint
 self.DoPaint()
 383, in DoPaint
 in UpdatePage
 hmin,hmax)
 SetRange
 OverflowError
 366, in OnPaint
 self.DoPaint()
 383, in DoPaint
 in UpdatePage
 hmin,hmax)
 SetRange
 OverflowError
 cannot convert float infinity to integer
 366, in OnPaint
 self.DoPaint()
 383, in DoPaint
 in UpdatePage
 hmin,hmax)
 SetRange
 OverflowError
 366, in OnPaint
 self.DoPaint()
 383, in DoPaint
 in UpdatePage
 hmin,hmax)
 SetRange
 OverflowError
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1961>
