[GRASS-dev] [GRASS GIS] #1963: wxGUI command console: "ls -" causes a traceback error
GRASS GIS trac at osgeo.org
Sat May 4 23:15:04 PDT 2013
 Reporter:  hamish           |       Owner:  grass-dev@…
     Type:  defect           |      Status:  new
 Priority:  minor            |   Milestone:  6.4.3
Component:  wxGUI            |     Version:  svn-releasebranch64
 Keywords:  command console  |    Platform:  All
      Cpu:  All              |
 if you go to the command console tab in the wxGUI and type 'ls -l' in the
 lower frame, you get this traceback error in the upper output frame as
 soon as you type the "-":
   File "/home/hamish/src/grass/svn/relbr_6_4/dist.x86_64
 -unknown-linux-gnu/etc/wxpython/gui_core/prompt.py", line
 969, in OnKeyPressed
 if self.toComplete['entity'] == 'flags' and self.cmdDesc:
 TypeError
 'NoneType' object is unsubscriptable
 both linux and wingrass.
 Hamish
 ps- see 2x ps- in #1936 report
Ticket URL: <https://trac.osgeo.org/grass/ticket/1963>
