[GRASS-dev] [GRASS GIS] #1849: Cannot create a new GRASS Location using a custom proj4 string
GRASS GIS trac at osgeo.org
Thu May 9 06:39:56 PDT 2013
 Reporter:  voncasec                       |       Owner:  grass-dev@…
     Type:  defect                         |      Status:  new
 Priority:  critical                       |   Milestone:  6.4.3
Component:  Projections/Datums             |     Version:  unspecified
 Keywords:  proj4, location wizard, wxgui  |    Platform:  Linux
      Cpu:  x86-64                         |
Comment(by hamish):
 setup by custom proj terms hopefully fixed & working ok in devbr6 as of
 r56176 (please test with your local!), similar fixes for epsg remain todo.
 an existing bug in the custom proj terms (maybe elsewhere too) is if you
 select datum transform opt `0` from the list (i.e. don't specify transform
 opts) it picks the grass default one anyway.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1849#comment:11>
