[GRASS-dev] GRASS 7 crashes on startup on Mac
Anna Petrášová
kratochanna at gmail.com
Mon May 13 15:32:57 PDT 2013
On Mon, May 13, 2013 at 11:51 PM, Michael Barton <Michael.Barton at asu.edu>wrote:
> Perhaps I discovered the problem. Both the distribution version
> (downloaded in the past hour) and (of course) the compiled version of
> menudata.xml are empty.
Yes, that's what I was thinking. Could you try to run this separately:
python core/toolboxes.py > xml/menudata.xml
which should be done during compilation but it seems to fail somehow. It
should generate the xml menu file.
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
> fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On May 13, 2013, at 2:18 PM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
> There might be a problem with compilation. Is there any error? Could you
> check file menudata.xml in gui/wxpython/xml/ and the same file in
> distribution? Is it there and what's inside?
> On Mon, May 13, 2013 at 10:51 PM, Michael Barton <Michael.Barton at asu.edu>wrote:
>> Anna,
>> I deleted all the GUI code and did a new svn up and make distclean.
>> Just finished compiling and have the same error on startup. The GUI
>> crashes.
>> Michael
>> ______________________________
>> C. Michael Barton
>> Tempe, AZ 85287-2402
>> USA
>> fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
>> www: http://csdc.asu.edu, http://shesc.asu.edu
>> On May 13, 2013, at 1:23 PM, Anna Petrášová <kratochanna at gmail.com>
>> wrote:
>> Hi Michael,
>> On Mon, May 13, 2013 at 9:52 PM, Michael Barton <Michael.Barton at asu.edu>wrote:
>>> I just compiled GRASS 7 Trunk.
>>> It crashes on startup with the following error:
>> this is related to the new toolboxes and menu customization. I don't
>> know what is wrong because it was tested successfully also on Windows.
>> Could you check what you have in directory toolboxes which should be in the
>> same folder as saved settings file? Also try make distclean or just make
>> clean in gui/wxpython and remove manually the gui files from distribution.
>> Anna
>>> GRASS 7.0.svn (nc_spm_08):~ > Traceback (most recent call last):
>>> File
>>> "/Users/Shared/grass_dev/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/wxgui.py",
>>> line 140, in <module>
>>> sys.exit(main())
>>> File
>>> line 133, in main
>>> app = GMApp(workspaceFile)
>>> File
>>> line 45, in __init__
>>> wx.App.__init__(self, False)
>>> File
>>> "/Users/Shared/grass_dev/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/python/wx/_core.py",
>>> line 7981, in __init__
>>> self._BootstrapApp()
>>> File
>>> line 7555, in _BootstrapApp
>>> return _core_.PyApp__BootstrapApp(*args, **kwargs)
>>> File
>>> line 79, in OnInit
>>> workspace = self.workspaceFile)
>>> File
>>> "/Users/Shared/grass_dev/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/lmgr/frame.py",
>>> line 106, in __init__
>>> self._menuTreeBuilder = LayerManagerMenuData()
>>> File
>>> "/Users/Shared/grass_dev/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/lmgr/menudata.py",
>>> line 31, in __init__
>>> MenuTreeModelBuilder.__init__(self, filename)
>>> File
>>> "/Users/Shared/grass_dev/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/core/menutree.py",
>>> line 61, in __init__
>>> xmlTree = etree.parse(filename)
>>> File
>>> "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/xml/etree/ElementTree.py",
>>> line 862, in parse
>>> tree.parse(source, parser)
>>> File
>>> line 587, in parse
>>> self._root = parser.close()
>>> File
>>> line 1254, in close
>>> self._parser.Parse("", 1) # end of data
>>> xml.parsers.expat.ExpatError: no element found: line 1, column 0
>>> No changes on my end since compiling it without a problem a week ago.
>>> Michael
>>> C. Michael Barton
>>> USA
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130514/313dbb80/attachment.html>
