[GRASS-dev] Compiling of GRASS from source under ubuntu - why do I need two raisins?????
Rainer M. Krug Rainer at krugs.de
Thu May 16 07:59:35 PDT 2013
Rainer at krugs.de (Rainer M. Krug) writes:
Sorry - the raisins are gone. It was a Chromium plugin whcih inserted
the text (Dictionary of numbers). But why it thought of raisins, no idea....
Cheers,
Rainer
> Hi
> I wanted to compile GRASS from source, and ended up in the kitchen
> looking for raisins:
> on
> http://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu#Dependencies
> it says:
> |   libncurses5-dev \
> |   zlib1g- [≈ Two raisins (approximately 1 gram)]dev gettext \
> |   libtiff-dev libpnglite-dev \
> As I then did not manage to squeeze them into my USB port, I decided to
> eat them.
> Seriously:
> I assume this is an innocent typo, or was it a hacker?
> Cheers,
> Rainer
<#secure method=pgpmime mode=sign>
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel :       +33 - (0)9 53 10 27 44
Cell:       +33 - (0)6 85 62 59 98
Fax :       +33 - (0)9 58 10 27 44
Fax (D):    +49 - (0)3 21 21 25 22 44
email:      Rainer at krugs.de
Skype:      RMkrug
