[GRASS-dev] use G_find_raster2() instead of G_find_raster()
Martin Landa landa.martin at gmail.com
Mon Nov 4 02:28:05 PST 2013
2013/11/4 Glynn Clements <glynn at gclements.plus.com>:
> Martin Landa wrote:
>> >> But I'm not able to decide on which occasion I want which function.
>> >> Someday, I can try to call both functions with different map/mapset
>> >> combinations but reading from manual would be more effective.
>> > Please use G_find_raster2() always (similarly for the other G_find_*
>> > functions). G_find_raster() exists for backward compatibility only.
>> > Having it modify the map name in-place has been the source of
>> > countless bugs.
>> it would be probably better to replace G_find_raster() by
>> G_find_raster2() in G7. Any objections?
> Not from me. For code which specifically needs an unqualified name,
> use G_unqualified_name() or G_name_is_fully_qualified().
perfect, is there any volunteer for this job? Unfortunately I will not
find time for that not earlier than in some weeks. And we should also
check other V2() functions.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
