[GRASS-dev] GRASS 6.4.svn on AIX based supercomputers
Markus Metz markus.metz.giswork at gmail.com
Tue Oct 1 00:20:12 PDT 2013
Have you included -R,/opt/freeware/lib in LDFLAGS? If not, you
probably should. See also GRASS wiki [0], there the entry for AIX 7.x.
Markus M
[0] http://grasswiki.osgeo.org/wiki/Compile_and_Install#AIX
On Mon, Sep 30, 2013 at 9:35 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi,
> I backported the relevant things from trunk, now GRASS 6.4.svn
> (upcoming 6.4.4) compiles on AIX powerpc systems, too!
> While this is fine:
> GRASS 6.4.4svn (patUTM32):~/software/grass-6.4.svn > g.version -r
> GRASS 6.4.4svn (2013)
> Revision: 50937
> Date: 2012-02-25 14:14:51 +0100 (Sat, 25 Feb 2012)
> I struggle here (same error as for GRASS 7 on the same system):
> GRASS 6.4.4svn (patUTM32):~/software/grass-6.4.svn > g.list vect
> Could not load program g.list:
>         Dependent module libstdc++.a(libstdc++.so.6) could not be loaded.
> Could not load module libstdc++.a(libstdc++.so.6).
> System error: No such file or directory
> GRASS 6.4.4svn (patUTM32):~/software/grass-6.4.svn > which g.list
> /gpfs/home/neteler/software/grass-6.4.svn/dist.powerpc-ibm-aix7.1.0.0/bin/g.list
> GRASS 6.4.4svn (patUTM32):~/software/grass-6.4.svn > ldd
> needs:
>          /gpfs/home/neteler/software/grass-6.4.svn/dist.powerpc-ibm-aix7.1.0.0/lib/libgrass_vect.6.4.4svn.so
>          /gpfs/home/neteler/software/grass-6.4.svn/dist.powerpc-ibm-aix7.1.0.0/lib/libgrass_dbmibase.6.4.4svn.so
>          /gpfs/home/neteler/software/grass-6.4.svn/dist.powerpc-ibm-aix7.1.0.0/lib/libgrass_gis.6.4.4svn.so
>          /gpfs/home/neteler/software/grass-6.4.svn/dist.powerpc-ibm-aix7.1.0.0/lib/libgrass_datetime.6.4.4svn.so
>          /usr/lib/libz.a(libz.so.1)
>          /gpfs/home/neteler/software/grass-6.4.svn/dist.powerpc-ibm-aix7.1.0.0/lib/libgrass_dbmiclient.6.4.4svn.so
>          /gpfs/home/neteler/software/grass-6.4.svn/dist.powerpc-ibm-aix7.1.0.0/lib/libgrass_dgl.6.4.4svn.so
>          /gpfs/home/neteler/software/grass-6.4.svn/dist.powerpc-ibm-aix7.1.0.0/lib/libgrass_dig2.6.4.4svn.so
>          /gpfs/home/neteler/software/grass-6.4.svn/dist.powerpc-ibm-aix7.1.0.0/lib/libgrass_rtree.6.4.4svn.so
>          /gpfs/home/neteler/software/grass-6.4.svn/dist.powerpc-ibm-aix7.1.0.0/lib/libgrass_linkm.6.4.4svn.so
> Cannot find libstdc++.a(libstdc++.so.6)
>          /usr/lib/libdl.a(shr_64.o)
>          /usr/lib/libiconv.a(libiconv.so.2)
> ar: 0707-109 Member name libiconv.so.2 does not exist.
> dump: /tmp/tmpdir4325472/extract/libiconv.so.2: 0654-106 Cannot open
> the specified file.
>          /gpfs/home/neteler/software/grass-6.4.svn/dist.powerpc-ibm-aix7.1.0.0/lib/libgrass_g3d.6.4.4svn.so
>          /usr/lib/libc.a(shr_64.o)
> Cannot find libgcc_s.a(shr.o)
>          /usr/lib/libc.a(shr.o)
>          /unix
>          /usr/lib/libcrypt.a(shr_64.o)
>          /usr/lib/libcrypt.a(shr.o)
> GRASS 6.4.4svn (patUTM32):~/software/grass-6.4.svn > ls -la
> /opt/freeware/lib64/ | grep std
> /opt/freeware/lib/ | grep std
> lrwxrwxrwx    1 root     system           44 Aug 27 19:24 libstdc++.a
> -> gcc/powerpc-ibm-aix7.1.0.0/4.6.1/libstdc++.a
> Any pointers?
> thanks
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
