[GRASS-dev] Handling of Python scripts on MS Windows
Anna Petrášová kratochanna at gmail.com
Wed Oct 2 09:57:01 PDT 2013
On Wed, Oct 2, 2013 at 12:32 PM, Pietro <peter.zamb at gmail.com> wrote:
> Hi Vaclav,
> On Wed, Oct 2, 2013 at 3:47 PM, Vaclav Petras <wenzeslaus at gmail.com>
> wrote:
> > I'm always for pure, correct and clean solutions. However, I'm not expert
> > neither in MS Windows registry nor in Python virtual environments nor in
> > covering .py to .exe and nobody provided other implementation, so I
> provided
> > mine which is messy but it only reflects mess which I---maybe just
> because
> > of my lack of knowledge---see on that system.
> Maybe, to resolve this issue, we can integrate in the windows
> installer the virtualenv[0] python package, as reported in the link:
> "virtualenv is a tool to create isolated Python environments". It
> should works with Windows... but I never used on this platform... I'm
> using virtualenv on linux, because the default python interpreter on
> my distribution is python3.x, and in this way I can easily test GRASS
> using different python versions (2.4, 2.6, 2.7).
> I'm ignorant on Windows and maybe virtualenv is useless in this
> case... or maybe integrate  virtualenv on the windows installer is too
> complex, I have no clue!
the question is: is anyone going to resolve this issue? Currently this is a
blocker for many Windows users which we can loose easily if we don't
provide solution soon enough.
Is this workaround worse than all the others which are already there?
Anna
> Pietro
> [0] https://pypi.python.org/pypi/virtualenv
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131002/db9cefb9/attachment.html>
