[GRASS-dev] Problem installing r.modis on trunk
Pierre Roudier pierre.roudier at gmail.com
Mon Oct 7 19:46:59 PDT 2013
I'm having a wee problem trying to compile r.modis on the trunk
version of GRASS. It does not seem to compile the pymodis library if
I'm getting that right:
GRASS 7.0.svn (eda-rsr):~ > g.extension ext=r.modis
Fetching <r.modis> from GRASS-Addons SVN (be patient)...
WARNING: gnome-keyring:: couldn't connect to:
/tmp/keyring-CTEtVP/pkcs11: No such file or directory
Compiling...
/bin/sh: 1: cannot create
/usr/local/grass-7.0.svn/locale/scriptstrings/r.modis.download_to_translate.c:
Directory nonexistent
sed: couldn't flush stdout: Broken pipe
make[1]: [/usr/local/grass-7.0.svn/locale/scriptstrings/r.modis.download_to_translate.c]
Error 2 (ignored)
/usr/local/grass-7.0.svn/locale/scriptstrings/r.modis.import_to_translate.c:
make[1]: [/usr/local/grass-7.0.svn/locale/scriptstrings/r.modis.import_to_translate.c]
Error 2 (ignored)
Installing...
Updating metadata file...
Installation of <r.modis> successfully finished
GRASS 7.0.svn (eda-rsr):~ > r.modis.import
ERROR: modis library not found
Is that a bug?
Cheers,
Pierre
Scientist
Landcare Research, New Zealand
