[GRASS-dev] [GRASS GIS] #2109: connect error in replacement of $MAPSET
GRASS GIS trac at osgeo.org
Wed Oct 16 05:11:46 PDT 2013
  Reporter:  lucadelu     |       Owner:  grass-dev@…
      Type:  enhancement  |      Status:  closed
  Priority:  normal       |   Milestone:  7.0.0
 Component:  Temporal     |     Version:  svn-trunk
Resolution:  fixed        |    Keywords:  connection
  Platform:  All          |         Cpu:  All
Changes (by huhabla):
  * status:  new => closed
  * type:  defect => enhancement
  * resolution:  => fixed
Comment:
 Replying to [comment:1 huhabla]:
 > You can use:
 > eval `g.gisenv`
 > To set $GISDBASE, $LOCATION_NAME and $MAPSET
 > I will modify the code of t.connect so that instead of the shell
 variables $GISDBASE and $LOCATION_NAME the real path variables are set in
 the module help to reduce confusion.
 Done in r58015
 > t.connect accepts as database argument a string that defines a database
 connection. In case of sqlite this must be a path. t.connect will not
 substitute shell variables itself if they are not set.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2109#comment:2>
