[GRASS-dev] i.pansharpen and Landsat 8
Nikos Alexandris nik at nikosalexandris.net
Wed Oct 23 05:40:33 PDT 2013
On Wednesday 23 of October 2013 12:48:16 Markus Neteler wrote:
> On Wed, Oct 23, 2013 at 10:09 AM, Yann Chemin <ychemin at gmail.com> wrote:
> > Using L8 with i.pansharpen gives nodata output, is it assuming 8-bit
> > datasets?
> I didn't have such problems, see
> http://courses.neteler.org/processing-landsat-8-data-in-grass-gis-7-rgb-comp
> osites-and-pan-sharpening/
Hi Markus.
I cannot confirm this :-(.  I only wish am completely wrong on this.  I tested
with LC81260592013137LGN01.
All bands are visible when drawn in "d.mon wx0" and they (i.e. B2, B3, B5 and
Pan) range in min=0, max=65535 (16-bit, unsigned). I MASKed the area of my
interest. I then ran
i.pansharpen ms3=B5 ms2=B3 ms1=B2 pan=B8 output=sharpen sharpen=ihs --v
All of the derived sharpen_* maps are of min=NULL, max=NULL. If I rescale them
to 8-bit, i.e.
r.rescale B2 out=B2_255 to=0,255
r.rescale B3 out=B2_255 to=0,255
r.rescale B3 out=B3_255 to=0,255
r.rescale B5 out=B5_255 to=0,255
!!:gs/B5/B8
it works fine. Both the data have a "valid" range, i.e. they are not NULLs,
and they are drawn perfectly fine on "d.mon wx0". For the records:
r.info sharpen_green -r
min=0
max=158
r.info sharpen_red -r
min=0
max=175
r.info sharpen_blue -r
min=0
max=144
Nikos
