[GRASS-dev] i.pansharpen and Landsat 8
Yann Chemin ychemin at gmail.com
Wed Oct 23 06:16:36 PDT 2013
I did not run i.landsat.toar, so data is still 16-bit, not float. Might be
the difference indeed.
On 23 October 2013 18:43, Moritz Lennert <mlennert at club.worldonline.be>wrote:
> On 23/10/13 12:48, Markus Neteler wrote:
>> On Wed, Oct 23, 2013 at 10:09 AM, Yann Chemin<ychemin at gmail.com>  wrote:
>>> Using L8 with i.pansharpen gives nodata output, is it assuming 8-bit
>>> datasets?
>> I didn't have such problems, see
>> http://courses.neteler.org/**processing-landsat-8-data-in-**
>> grass-gis-7-rgb-composites-**and-pan-sharpening/<http://courses.neteler.org/processing-landsat-8-data-in-grass-gis-7-rgb-composites-and-pan-sharpening/>
> In the first part of that tutorial, you run i.landsat.toar on the data.
> Could that make a difference ?
> Moritz
> ______________________________**_________________
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/grass-dev<http://lists.osgeo.org/mailman/listinfo/grass-dev>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131023/07899f0d/attachment.html>
