[GRASS-dev] [GRASS GIS] #2067: PyGRASS grid calls g.region at	import time
    trac at osgeo.org
    Sun Sep  1 01:29:09 PDT 2013
 Reporter:  huhabla        |       Owner:  grass-dev@…
     Type:  defect        |      Status:  new
 Priority:  normal        |   Milestone:  7.0.0
Component:  Python        |     Version:  svn-trunk
 Keywords:  PyGRASS, Grid, Python, temporal framework, t.remove, t.rast.neighbors  |    Platform:  MSWindows 7
      Cpu:  Unspecified                                                            |
 There is an issue in pygrass that prevent the compilation of the temporal
 framework on windows[1,2]. The issue appears while importing
 grass.pygrass.modules.grid.grid. While import a new Module instance is
 created for g.region.
 IMHO its not a good decision to call a grass module directly on import. I
 would suggest to create a Module variable in GridModule that is only once
 created at the construction of the first GridModule object in a process
 (singleton).
 [1] http://wingrass.fsv.cvut.cz/grass70/logs/log-r57559-690/error.log
 [2]
   File "c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
 mingw32/scripts/t.remove.py", line 58, in <module>
     import grass.pygrass.modules as pyg
   File "c:\osgeo4w\usr\src\grass_trunk\dist.i686-pc-
 mingw32\etc\python\grass\pygrass\__init__.py", line 17, in <module>
     import modules
 mingw32\etc\python\grass\pygrass\modules\__init__.py", line 11, in
 <module>
     import grid
 mingw32\etc\python\grass\pygrass\modules\grid\__init__.py", line 9, in
 <module>
     import grid
 mingw32\etc\python\grass\pygrass\modules\grid\grid.py", line 23, in
 <module>
     _GREG = Module('g.region')
 mingw32\etc\python\grass\pygrass\modules\interface\module.py", line 244,
 in __init__
     raise GrassError(str_err % self.name)
 grass.pygrass.errors.GrassError: "Module 'g.region' not found, please
 check that the module exist"
 make[3]: *** [t.remove.tmp.html] Error 1
Ticket URL: <http://trac.osgeo.org/grass/ticket/2067>
