[GRASS-dev] issue with vector import wrapper for v.in.ogr for GRASS 7
Michael Barton Michael.Barton at asu.edu
Thu Sep 5 19:03:25 PDT 2013
I just did a test and the wrapper for r.in.gdal and wrapper for v.in.ogr crash the GUI when I click the "browse" button.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Sep 3, 2013, at 6:35 AM, Anna Petrášová <kratochanna at gmail.com<mailto:kratochanna at gmail.com>> wrote:
On Mon, Sep 2, 2013 at 3:20 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
I received a report that the wrapper for v.in.ogr is throwing an error when importing files of multiple types (kml and shp tested). The error in the terminal is:
pythonw2.6(5979,0xad1e72c0) malloc: *** error for object 0x6d353ed5: pointer being freed was not allocated
*** set a breakpoint in malloc_error_break to debug
v.in.ogr works fine for the same files. So it is the wrapper.
This is happening in GRASS 7 r57457, compiled 16 August. That's a couple weeks back, so it may be fixed. If not, I can do a ticket.
this is a strange error, does this happen on certain platforms only? And when exactly does this error appear, when you press Import?
Anna
Michael
C. Michael Barton
voice:  480-965-6262<tel:480-965-6262> (SHESC), 480-965-8130/727-9746 (CSDC)
fax:          480-965-7671<tel:480-965-7671> (SHESC),  480-727-0709<tel:480-727-0709> (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu<http://csdc.asu.edu/>
grass-dev mailing list
grass-dev at lists.osgeo.org<mailto:grass-dev at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130906/d0d52b0c/attachment.html>
