[GRASS-dev] [GRASS GIS] #2067: PyGRASS grid calls g.region at import time
GRASS GIS trac at osgeo.org
Sat Sep 7 21:09:15 PDT 2013
 Reporter:  huhabla        |       Owner:  grass-dev@…
     Type:  defect        |      Status:  new
 Priority:  blocker        |   Milestone:  7.0.0
Component:  Python        |     Version:  svn-trunk
 Keywords:  wingrass, PyGRASS, Grid, Python, temporal framework, t.remove, t.rast.neighbors  |    Platform:  MSWindows 7
      Cpu:  Unspecified        |
Comment(by hamish):
 fwiw,
 trunk/lib/python/pygrass/modules/grid/grid.py line 23 from the traceback
 has:
   _GREG = Module('g.region')
 which is used within cmd_exe(), to "Create a mapset, and execute a cmd
 inside."
 there are a number of other Module() aliases created within, but no other
 at the top level of the file, all the others are within a function
 definition. (but if it stops on the first error maybe that's irrelevant)
 The Module() class is defined in
 trunk/lib/python/pygrass/modules/interface/module.py, the line there where
 the above failure is caught (L244) is:
     def __init__(self, cmd, *args, **kargs):
         self.name = cmd
         try:
             # call the command with --interface-description
             get_cmd_xml = subprocess.Popen([cmd, "--interface-
 description"],
                                            stdout=subprocess.PIPE)
         except OSError:
             str_err = "Module %r not found, please check that the module
 exist"
             raise GrassError(str_err % self.name)
 so apparently during the build anything calling that initialization
 function would want to be run in a dummy session, as is done to generate
 the header usage text for the html help pages. or the pygrass code change
 to simply skip past the step with a warning message if GISBASE is not set
 to anything.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2067#comment:3>
