[GRASS-dev] [GRASS GIS] #1941: wxGUI fails with Japanese locale
GRASS GIS trac at osgeo.org
Wed Sep 11 02:43:58 PDT 2013
 Reporter:  venkat    |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  blocker   |   Milestone:  7.0.0
Component:  wxGUI     |     Version:  svn-trunk
 Keywords:  wingrass  |    Platform:  MSWindows 7
      Cpu:  x86-32    |
Comment(by mlennert):
 Replying to [comment:21 martinl]:
 > Replying to [comment:19 martinl]:
 > > > [http://msdn.microsoft.com/en-
 us/library/windows/desktop/ms682586%28v=vs.85%29.aspx DLL Search Order].
 > > Right, when I launch `python.exe` which comes with standalone
 installer it points to `C:Windows\SysWOW64\python27.dll`. When I launch
 `python.exe` from `C:\OSGeo4W\bin` it points to the right dll file, ie.
 `C:\OSGeo4W\bin\python27.dll`.
 > Ah, OK, it's probably caused by the fact that the standalone installer
 puts `python27.dll` to the different directory (ie. `extralib`) compared
 to `python.exe` (`extrabin`). Directory `extralib` is in the path
 source:grass/trunk/mswindows/env.bat#L17, but it's probably not enough.
 The problem could be solved by moving `python27.dll` to `extrabin`. Then
 we could probably move all DLL files to `extrabin` and get rid of this
 directory. It's comment practice to have DLL files together with EXE files
 in the same directory. I don't know why the standalone installer separates
 them to the two different directories, ie. `extrabin` and `extralib`.
 Try it, but ISTR that there is also an issue with the Windows registry,
 i.e. that the dlls called depend on registry entries (I think that this
 came up as a problem at least in the case of python scripts called from
 python scripts).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1941#comment:22>
