[GRASS-dev] [GRASS GIS] #2078: New tool: Ability to draw a region (computation range) from the map display module
GRASS GIS trac at osgeo.org
Sun Sep 15 14:48:02 PDT 2013
module
 Reporter:  vesnikos     |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  6.4.4
Component:  wxGUI        |     Version:  svn-trunk
 Keywords:               |    Platform:  All
      Cpu:  All          |
Comment(by vesnikos):
 Hey Hamish,
 Yeah, I know about that module but im not sure if you can specify the
 region.
 Usually I identify visually a spot in my raster where a certain algorithm
 needs to be run. mostly holes that need to be filled with r.fillnulls. So
 I don't need it for the hole raster. Just for that spot. So preserving the
 raster's resolution makes sense. Plus its trivial to change it the res
 flag of 'g.region'.
 If you have to do that more than three times, its too time consuming to
 querry the edges, and then plug them in g.region
 What I had in mind is more like a functionality like the 'zoomIn' button,
 but instead of zooming in, it should change the computational extents of
 the rectangle you draw.
 Nikos
Ticket URL: <https://trac.osgeo.org/grass/ticket/2078#comment:3>
