[GRASS-dev] [GRASS GIS] #2080: wxGUI: changing properties of barscale or legend
GRASS GIS trac at osgeo.org
Mon Sep 16 02:15:34 PDT 2013
 Reporter:  martinl      |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  wxGUI        |     Version:  unspecified
 Keywords:  decorations  |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by mlennert):
 Replying to [ticket:2080 martinl]:
 > Hi,
 > when changing properties of barscale or legend you need to go through
 two dialogs. The first dialog allows to disable/enable decoration and
 launch properties (autogenerated) dialog. Here 'Apply' button has no
 effect, so you cannot see immediately the change. You close the properties
 dialog and then the first dialog. After these steps decoration is re-
 rendered.
 > My suggestion is to avoid the first dialog. Clicking on decoration would
 launch properties dialog immediately. Right click shows contextual menu
 with one item 'Hide'. To show decoration you would go to the toolbar and
 to add selected decoration again.
 +1
Ticket URL: <http://trac.osgeo.org/grass/ticket/2080#comment:1>
