[GRASS-dev] redirect graphic output of r.spread
Margherita Di Leo dileomargherita at gmail.com
Wed Sep 18 01:31:20 PDT 2013
On Wed, Sep 18, 2013 at 1:07 AM, Hamish <hamish_b at yahoo.com> wrote:
> Margherita wrote:
> > Any idea on how to (and IF it's possible to) redirect the graphic
> > output of r.spread module to a gif or mov or avi file instead of
> > to (or beside to) the monitor?
> not directly, but you might see the "screencast" section in:
>   http://grasswiki.osgeo.org/wiki/Movies
Thanks for the link. But I don't understand how to put this in practice. I
mean, as far as I understand, you're suggesting to run r.spread in a loop,
each step producing a final map as image and then compose together as a
video, right? I had also thought something of the kind, but I was looking
for a way to save the detailed fire evolution as it is generated by
r.spread, hence a way to redirect the output directly to a video, or at
least save several static images while r.spread is running, and then to
compose them as a movie. Is that feasible?
Thanks
Best regards,
Dr. Margherita DI LEO
Scientific / technical project officer
European Commission - DG JRC
Institute for Environment and Sustainability (IES)
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo at jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not
in any circumstance be regarded as stating an official position of the
European Commission.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130918/666b3e32/attachment-0001.html>
