[GRASS-dev] [GRASS GIS] #1997: i.landsat.toar for grass-dev is missing the option for landsat8
GRASS GIS trac at osgeo.org
Fri Sep 27 04:28:57 PDT 2013
 Reporter:  vesnikos        |       Owner:  grass-dev@…
     Type:  defect          |      Status:  new
 Priority:  normal          |   Milestone:  7.0.0
Component:  Imagery         |     Version:  svn-trunk
 Keywords:  i.landsat.toar  |    Platform:  All
      Cpu:  Unspecified     |
Comment(by nikosa):
 Replying to [comment:7 nikosa]:
 > Replying to [comment:6 vesnikos]:
 > > some minor bugs during my tests:
 > > 2) Band8 (panchomatic) has my nature 15m res. The algorithm uses the
 regions resolution , and you cannot do anything to override it.
 > You can set the region resolution to the desired one!  In my scripts I
 do that.  Maybe in this case an exception could be done and let the module
 handle this?
 This look more important than I thought in the beginning.  Indeed, one
 needs to work-around that issue since there is no way to preserve the
 15m-s of Band 8 using (the current) i.landsat.toar in one go.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1997#comment:10>
