[GRASS-dev] [GRASS GIS] #1997: i.landsat.toar for grass-dev is missing the option for landsat8
Nick Ves vesnikos at gmail.com
Fri Sep 27 09:35:34 PDT 2013
new ticket about the resolution issue:
https://trac.osgeo.org/grass/ticket/2089
On Fri, Sep 27, 2013 at 7:27 PM, Nick Ves <vesnikos at gmail.com> wrote:
> Yeah its still open - It shouldn't since the main problem is fixed. I'll
> open a new ticket for the the resolution bug.
> BTW, I have made a script that does what i.landsat.toar does, only that
> its fixed in that regard. I'll be more than happy to share it if someone
> needs it!
> N
>>  Reporter:  vesnikos        |       Owner:  grass-dev@…
>>      Type:  defect          |      Status:  new
>>  Priority:  normal          |   Milestone:  7.0.0
>> Component:  Imagery         |     Version:  svn-trunk
>>  Keywords:  i.landsat.toar  |    Platform:  All
>>       Cpu:  Unspecified     |
>> Comment(by nikosa):
>>  Replying to [comment:7 nikosa]:
>>  > Replying to [comment:6 vesnikos]:
>>  > > some minor bugs during my tests:
>>  > > 2) Band8 (panchomatic) has my nature 15m res. The algorithm uses the
>>  regions resolution , and you cannot do anything to override it.
>>  > You can set the region resolution to the desired one!  In my scripts I
>>  do that.  Maybe in this case an exception could be done and let the
>> module
>>  handle this?
>>  This look more important than I thought in the beginning.  Indeed, one
>>  needs to work-around that issue since there is no way to preserve the
>>  15m-s of Band 8 using (the current) i.landsat.toar in one go.
>> Ticket URL: <http://trac.osgeo.org/grass/ticket/1997#comment:10>
>> GRASS GIS <http://grass.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130927/4d96a7eb/attachment.html>
