[GRASS-dev] [GRASS GIS] #2240: wxGUI: measurement tool does not show line after first click
GRASS GIS trac at osgeo.org
Wed Apr 2 01:56:00 PDT 2014
 Reporter:  neteler      |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  wxGUI        |     Version:  svn-trunk
 Keywords:  d.measure    |    Platform:  Linux
      Cpu:  Unspecified  |
Changes (by neteler):
  * platform:  Unspecified => Linux
  * version:  svn-releasebranch70 => svn-trunk
Comment:
 Replying to [comment:2 annakrat]:
 > Does this happen to you with freshly opened gui?
 Yes. g.gui, Load raster map, "Measure distance", no line attached after
 first click.
 At a second click the line is drawn between the points.
 I would note that the line digitizer tool in wxdigit is much nicer since
 it reports
 in the map display bottom bar rather than (unexpectedly) in the command
 console which
 is commonly not open.
 System Info
 GRASS version: 7.1.svn
 GRASS SVN Revision: 59549M
 Build Date: 2014-04-02
 Build Platform: x86_64-unknown-linux-gnu
 GDAL/OGR: 1.10.1
 PROJ.4: 4.8.0
 GEOS: 3.4.2
 SQLite: 3.8.4
 Python: 2.7.5
 wxPython: 2.8.12.0
 Platform: Linux-3.13.6-200.fc20.x86_64-x86_64-with-fedora-20-Heisenbug
Ticket URL: <http://trac.osgeo.org/grass/ticket/2240#comment:3>
