[GRASS-dev] [Qgis-developer] GRASS & QGIS: the future
William Kyngesburye woklist at kyngchaos.com
Tue Apr 8 07:11:05 PDT 2014
This is how it looks for me (Mt Lion, should be same on Mavericks) - you see the grass mapsets inside the grass DB (I have some other junk in mine), the DB doesn't get any special treatment:
On Apr 8, 2014, at 9:03 AM, Radim Blazek <radim.blazek at gmail.com> wrote:
> On Tue, Apr 8, 2014 at 3:54 PM, Rainer M Krug <Rainer at krugs.de> wrote:
>> Radim Blazek <radim.blazek at gmail.com> writes:
>>> On Tue, Apr 8, 2014 at 2:18 PM, Moritz Lennert
>>> <mlennert at club.worldonline.be> wrote:
>>>> On 28/03/14 15:16, Paolo Cavallini wrote:
>>>>> Il 28/03/2014 15:04, Martin Dobias ha scritto:
>>>>>> On Fri, Mar 28, 2014 at 11:48 AM, Paolo Cavallini <cavallini at faunalia.it>
>>>>>> wrote:
>>>>>>> * to add GRASS browsing capabilities in QGIS file browser
>>>>>> The support for GRASS is already in the browser - if you enter a
>>>>>> directory that is a GRASS database, it will detect it and show
>>>>>> locations/mapsets/maps/layers.
>>>>> That's great news, never tried. Works beautifully, thanks.
>>>> I cannot reproduce this. How does it work exactly ? When I browse into a
>>>> GRASS database directory, it just shows up like any other directory.
>>> The GRASS location is added as another item with GRASS icon in the
>>> tree on the same level where is the location dir. It means that the
>>> location will appear twice, first as regular dir and then as a GRASS
>>> location. The items do not seem to be sorted by name, so maybe you
>>> have to scroll down.
>> Hm - I think I also need a step-by-step guide. I am using QGIS 2.2.0 on
>> OSX Maverick and I don't get it to work.
>> 0) Open QGIS
>> 1) I open the browser (View - Panels - Browser)
>> 2) Then I go via the Home folder (top entry) to a GRASS database
>> 3) and now, where should I see what? What is the root in the tree
>> structure? I can only see the folder structure.
> Probably a bug. It is checking for location/PERMANENT/DEFAULT_WIND.
> You have maybe lower case names? If so, can you test with upper?
> Please fill a new issue.
> Radim
>> Rainer
>>> Radim
>>>> Moritz
>>>> _______________________________________________
>>>> grass-dev mailing list
>>>> grass-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
>> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
>> Centre of Excellence for Invasion Biology
>> Stellenbosch University
>> South Africa
>> Tel :       +33 - (0)9 53 10 27 44
>> Cell:       +33 - (0)6 85 62 59 98
>> Fax :       +33 - (0)9 58 10 27 44
>> Fax (D):    +49 - (0)3 21 21 25 22 44
>> email:      Rainer at krugs.de
>> Skype:      RMkrug
>> PGP: 0x0F52F982
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140408/ded98c60/attachment-0001.html>
Name: Screen Shot 2014-04-08 at 9.06.32 AM.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140408/ded98c60/attachment-0001.png>
