[GRASS-dev] [GRASS GIS] #2267: t.list doesn't respect search path
GRASS GIS trac at osgeo.org
Tue Apr 29 10:49:07 PDT 2014
 Reporter:  martinl              |       Owner:  grass-dev@…
     Type:  defect               |      Status:  new
 Priority:  normal               |   Milestone:  7.0.0
Component:  Temporal             |     Version:  svn-trunk
 Keywords:  t.list, search path  |    Platform:  Unspecified
      Cpu:  Unspecified          |
Comment(by annakrat):
 In animation tool, when you don't provide the name without mapset, I try
 to guess the mapset and the first would be the `modis at landamar`. So I am
 not sure if this
 [http://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/animation/utils.py#L58
 function] is wrong or if the output of t.list is wrong. t.list just gives
 back the result of a SELECT in a database ordered alphabetically. Should
 t.list return the results based on the search path if user doesn't specify
 order? Or we perhaps need a function in the temporal API which would
 behave like g.findfile? How is this solved in the temporal modules?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2267#comment:1>
