[GRASS-dev] sample dataset for temporal data
Anna Petrášová
kratochanna at gmail.com
Tue Apr 29 14:07:39 PDT 2014
since more and more users are using temporal framework, we should consider
creating a sample dataset for temporal data. This could be used in the
manual pages of t.* modules. Some of them still don't have any example and
the existing examples are based on tests with generated data which is not
the best way.
Some time ago I created a climate dataset for North Carolina from publicly
available data, it has monthly temperature average and monthly
precipitation from 2000 to 2012. You can download it from here:
http://courses.ncsu.edu/mea592/common/media/02/nc_climate_spm_2000_2012.zip
There are no temporal vector data, just the standard precip. stations
vector from nc_spm_08.
So I suggest to use this, because it's consistent with nc_spm_08 but feel
free to suggest something else.
Best,
Anna
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140429/f2be4750/attachment.html>
