[GRASS-dev] GRASS 7.0 beta3 problems on Mac
Michael Barton Michael.Barton at asu.edu
Mon Aug 11 12:58:13 PDT 2014
It looks like $(DSTDIR) is missing for the references to the relevant xml files in lines 29-43 of the make file for wxpython.
I am testing, but someone who is more familiar than I am with makefiles should check this.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Aug 11, 2014, at 12:47 PM, Michael Barton <michael.barton at asu.edu<mailto:michael.barton at asu.edu>> wrote:
Maybe here is the cause of this recurring problem.
The ‘bogus’ errors for the windowing may still be bogus.
The problem with starting GRASS has to do with the fact that a couple of the xml files for the new (and still unused?) “toolbox” do not get made. But SOME of them DO get made. Here is the call that successfully makes one of the xml files and a call that fails. Note that the full path is not specified in the one that fails.
This one works:
/Applications/Xcode.app/Contents/Developer/usr/bin/make /Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/gui/wxpython/xml/module_items.xml
This one fails:
/Applications/Xcode.app/Contents/Developer/usr/bin/make xml/menudata.xml
Looks to me like it SHOULD be calling
/Applications/Xcode.app/Contents/Developer/usr/bin/make /Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/gui/wxpython/xml/menudata.xml
Michael
C. Michael Barton
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu<http://csdc.asu.edu/>
On Aug 11, 2014, at 12:24 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
I just tried to compile GRASS 7.0 beta 3 for release and it appears to be broken. It worked fine 15 July. Here are the problems.
1st, there is a set of GUI errors that pop up from make. These were present awhile back but ‘bogus’ in that they did not seem to affect running (though I suspected that they were related to other issues that caused compiling problem). These went away and all was well by the mid-July build. But they are back again. I hoped that they were again ‘bogus’ but the GUI won’t launch now.
Here are the errors on launch:
======================= launch errors ================
GRASS 7.0.0svn (nc_spm_08):~ > Traceback (most recent call last):
  File "/Users/cmbarton/grass_source/grass7_rb/macosx/dist/GRASS-7.0.app/Contents/MacOS/gui/wxpython/wxgui.py", line 138, in <module>
    sys.exit(main())
  File "/Users/cmbarton/grass_source/grass7_rb/macosx/dist/GRASS-7.0.app/Contents/MacOS/gui/wxpython/wxgui.py", line 131, in main
    app = GMApp(workspaceFile)
  File "/Users/cmbarton/grass_source/grass7_rb/macosx/dist/GRASS-7.0.app/Contents/MacOS/gui/wxpython/wxgui.py", line 45, in __init__
    wx.App.__init__(self, False)
  File "/Users/cmbarton/grass_source/grass7_rb/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/python/wx/_core.py", line 7981, in __init__
    self._BootstrapApp()
  File "/Users/cmbarton/grass_source/grass7_rb/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/python/wx/_core.py", line 7555, in _BootstrapApp
    return _core_.PyApp__BootstrapApp(*args, **kwargs)
  File "/Users/cmbarton/grass_source/grass7_rb/macosx/dist/GRASS-7.0.app/Contents/MacOS/gui/wxpython/wxgui.py", line 79, in OnInit
    workspace = self.workspaceFile)
  File "/Users/cmbarton/grass_source/grass7_rb/macosx/dist/GRASS-7.0.app/Contents/MacOS/gui/wxpython/lmgr/frame.py", line 118, in __init__
    self._menuTreeBuilder = LayerManagerMenuData()
  File "/Users/cmbarton/grass_source/grass7_rb/macosx/dist/GRASS-7.0.app/Contents/MacOS/gui/wxpython/lmgr/menudata.py", line 40, in __init__
    MenuTreeModelBuilder.__init__(self, filename, expandAddons=expandAddons)
  File "/Users/cmbarton/grass_source/grass7_rb/macosx/dist/GRASS-7.0.app/Contents/MacOS/gui/wxpython/core/menutree.py", line 64, in __init__
    xmlTree = etree.parse(filename)
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py", line 1182, in parse
    tree.parse(source, parser)
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py", line 657, in parse
    self._root = parser.close()
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py", line 1654, in close
    self._raiseerror(v)
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py", line 1506, in _raiseerror
    raise err
xml.etree.ElementTree.ParseError: no element found: line 1, column 0
This looks like the same error that I’d had to deal with earlier, but which appeared fixed by the mid-July build. I have a workaround but it is a PITA.
The make errors are here. As before they all are related to a new windowing environment:
================== list of modules with make errors ===========
Errors in:
Errors in:
/Users/cmbarton/grass_source/grass7_rb/gui/wxpython/animation
/Users/cmbarton/grass_source/grass7_rb/gui/wxpython/mapswipe
/Users/cmbarton/grass_source/grass7_rb/gui/wxpython/gmodeler
/Users/cmbarton/grass_source/grass7_rb/gui/wxpython/rlisetup
/Users/cmbarton/grass_source/grass7_rb/gui/wxpython/psmap
/Users/cmbarton/grass_source/grass7_rb/gui/wxpython/dbmgr
/Users/cmbarton/grass_source/grass7_rb/gui/wxpython/vdigit
/Users/cmbarton/grass_source/grass7_rb/gui/wxpython/iclass
/Users/cmbarton/grass_source/grass7_rb/gui/wxpython/gcp
/Users/cmbarton/grass_source/grass7_rb/gui/wxpython/timeline
Here is an example of the error in one of the above modules:
 cd /Users/cmbarton/grass_source/grass7_rb/gui/wxpython/animation
cmb-imaccsdc:animation cmbarton$ make
/Applications/Xcode.app/Contents/Developer/usr/bin/make /Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/docs/html/g.gui.animation.html
GISRC=/Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/demolocation/.grassrc70 GISBASE=/Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0 PATH="/Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/bin:/Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/bin:/Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/scripts:$PATH" PYTHONPATH="/Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/etc/python:/Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/gui/wxpython:$PYTHONPATH" DYLD_LIBRARY_PATH="/Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/bin:/Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/scripts:/Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/lib:/Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/lib:" LC_ALL=C /Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/scripts/g.gui.animation --html-description < /dev/null | grep -v '</body>\|</html>' > g.gui.animation.tmp.html
  File "/Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/scripts/g.gui.animation", line 55, in <module>
    import wx
  File "/usr/local/lib/wxPython-unicode-2.8.12.1/lib/python2.7/site-packages/wx-2.8-mac-unicode/wx/__init__.py", line 45, in <module>
    from wx._core import *
  File "/usr/local/lib/wxPython-unicode-2.8.12.1/lib/python2.7/site-packages/wx-2.8-mac-unicode/wx/_core.py", line 4, in <module>
    import _core_
ImportError: /usr/local/lib/wxPython-unicode-2.8.12.1/lib/python2.7/site-packages/wx-2.8-mac-unicode/wx/_core_.so: no appropriate 64-bit architecture (see "man python" for running in 32-bit mode)
make[1]: *** [g.gui.animation.tmp.html] Error 1
rm g.gui.animation.tmp.html
make: *** [guiscript] Error 2
In fact I DO have this set up to compile and run Python in 32 bit mode. I’ve been doing this for a couple years while waiting for wxPython 64 bit to stabilize and mature (not there yet as of 2.9).
This all worked a couple weeks ago, which makes this frustrating.
I can try the new wxPython 3.0 but I have no idea whether it works with the current GRASS GUI.
Michael
C. Michael Barton
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140811/762d6c69/attachment-0001.html>
