[GRASS-dev] [GRASS GIS] #2392: winGRASS GIS 6.4.5 svn r.li modules - issues with hard coded path to conf files
GRASS GIS trac at osgeo.org
Sun Aug 17 09:21:33 PDT 2014
files
 Reporter:  hellik          |       Owner:  grass-dev@…
     Type:  defect          |      Status:  new
 Priority:  critical        |   Milestone:  6.4.5
Component:  Raster          |     Version:  svn-releasebranch64
 Keywords:  wingrass, r.li  |    Platform:  MSWindows 7
      Cpu:  x86-32          |
Comment(by hellik):
 Replying to [comment:5 neteler]:
 > Replying to [ticket:2392 hellik]:
 > > from the ML
 > > http://lists.osgeo.org/pipermail/grass-dev/2014-August/070384.html
 > > now conf-file generated in winGRASS7.1svn and the conf file stored
 e.g.
 > > C:\Users\normal\AppData\Roaming\GRASS6\movwindow7
 > Note that the r.li directory is different in GRASS GIS 6 from than what
 you tried:
 as setup is not working at the moment in winGRASS6, I've created the conf
 file in winGRASS7; and there are different places in winGRASS6 and
 winGRASS7 where the conf file is stored by r.li.setup
 > # Linux
 > $HOME/.r.li/history/movwindow7
 > # Windows (untested, please test)
 > C:\Users\normal\AppData\Roaming\GRASS6\.r.li\history\movwindow7
 in winGRASS6, it's
 C:\Users\normal\.r.li
 in winGRASS7, it's
 C:\Users\normal\AppData\Roaming\GRASS7
 > ... and no path in conf= when running the r.li.* modules.
 > See also:
 http://grasswiki.osgeo.org/wiki/GRASS_configuration_files_in_home_directory
 > You may try to use 'g.gisenv set="DEBUG=1"' to check where r.li.* is
 seeking.
 as noted before, it's seeked in
 > Once understood, we should add a note in
 grass64/raster/r.li/r.li.setup/description.html
 yes
Ticket URL: <http://trac.osgeo.org/grass/ticket/2392#comment:6>
