[GRASS-dev] GRASS7relbr/GRASS7trunk: GUI error message: ascii' codec can't decode byte 0xc3 in position 11: ordinal not in range(128)
Helmut Kudrnovsky hellik at web.de
Wed Aug 20 04:55:06 PDT 2014
any command, where input (vector/raster-modules: e.g. r.contour, v.drape,
etc.) _and_ output is needed in one GUI tab, gives an error message, when
input is selected:
e.g. r.contour
  File "C:\OSGeo4W\apps\grass\grass-7.0.0svn\gui\wxpython\gu
i_core\forms.py", line 2146, in OnSetValue
self.OnUpdateValues(event)
i_core\forms.py", line 615, in updateValuesHook
self.SetStatusText('
'.join(self.notebookpanel.createCmd(ignoreErrors = True)))
UnicodeDecodeError
'ascii' codec can't decode byte 0xc3 in position 11: ordinal
not in range(128)
some encoding issues?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/GRASS7relbr-GRASS7trunk-GUI-error-message-ascii-codec-can-t-decode-byte-0xc3-in-position-11-ordinal--tp5157311.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
