[GRASS-dev] Tabs and spaces in C code
Fri Aug 22 04:16:40 PDT 2014
Vaclav Petras wrote:
> > The "rules" are that indentation in multiples of 4 columns, and we
> > don't care whether that indentation is acheived through spaces or
> > tabs.
> So, since we are providing a script and standard for indentation, let's use
> only spaces* in this script (rather then enforcing mixing of tabs and
> spaces when there is no reason for it).
Some might consider the reduction in file size to be a reason for
using tabs. I have no opinion either way.
