[GRASS-dev] Some minor TGIS issues in GRASS 7.1
Sören Gebbert soerengebbert at googlemail.com
Mon Aug 25 08:55:09 PDT 2014
Hi Stefan,
many thanks for your feedback, it is really appreciated.
We will fix this bug in a major code review and overhaul. Thomas
(Author of the temporal algebra code) and i are revisiting the
temporal algebra at the moment. We will introduce several changes
regarding the functionality and the algebra syntax. The temporal
algebra code is still very experimental and needs further testing. We
are still working on the general concept of the algebra, that will
eventually result in a paper.
Best regards
Soeren
2014-08-22 13:22 GMT+02:00 Blumentrath, Stefan <Stefan.Blumentrath at nina.no>:
> One additional thing:
> t.rast.mapcalc2 does not seem to read STDS from other mapsets. I get a parse error regardless if I use full map names with mapset specified (then expression parsing seems to break at the "at") or if I add the other mapset to the current search path and do not specify the mapset in the expression (in the latter case the modul complains that the map cannot be found in the current mapset)?
> Anyone who can confirm?
> Cheers
> Stefan
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
