[GRASS-dev] check on GRASS revision number
Michael Barton Michael.Barton at asu.edu
Thu Dec 4 09:26:56 PST 2014
That’s very good to know.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Dec 2, 2014, at 1:37 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi,
> just for the record, by chance it happened to me today and how I
> solved it easily:
> GRASS 7.0.0svn (nc_spm_08_grass7):~ > r.stream.order
> stream_rast=streams at user1 direction=direction at user1
> elevation=elevation at PERMANENT accumulation=accum at user1
> stream_vect=streams horton=horton
> ERROR: Module built against version $Revision: 62395 $ but trying to use
>       version $Revision: 63222 $. You need to rebuild GRASS GIS or
>       untangle multiple installations.
> # Now simply re-run g.extension:
> GRASS 7.0.0svn (nc_spm_08_grass7):~ > g.extension r.stream.order
> WARNING: Extension <r.stream.order> already installed. Re-installing...
> Fetching <r.stream.order> from GRASS-Addons SVN repository (be patient)...
> Compiling...
> Installing...
> Updating metadata file...
> Installation of <r.stream.order> successfully finished
> # enjoy:
> All in RAM calculation...
> Reading raster map <streams at user1>...
> 100%
> Reading raster map <direction at user1>...
> 100%
> Finding nodes...
> Finding longest streams...
> Calculating Strahler's stream order...
> Calculating Hortons's stream order...
> Calculating Shreve's stream magnitude, Scheidegger's consistent integer and
> Drwal's streams hierarchy (old style)...
> Calculating Hack's main streams and topological dimension...
> Building topology for vector map <streams at user1>...
> Writing outpout raster maps...
> Hope this helps,
> Markus
