[GRASS-dev] [GRASS GIS] #2509: d.mon output overwrite
GRASS GIS trac at osgeo.org
Sun Dec 7 08:29:31 PST 2014
 Reporter:  martinl      |       Owner:  martinl
     Type:  defect       |      Status:  assigned
 Priority:  normal       |   Milestone:  7.0.0
Component:  Display      |     Version:  unspecified
 Keywords:  d.mon        |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by wenzeslaus):
 This applies to any `d.*` command which is drawing something.
 Start GRASS and use in terminal:
 d.rast elevation
 `map.png` now contains image of elevation raster.
 d.vect streams
 `map.png` now contains image of streams vector.
 You don't need to call `d.mon` in order to write to a file named
 `map.png`. So, I'm not sure if what you are reporting, is an bug. It is
 perhaps just undocumented feature. The unchecked overwrite is a bit
 inconsistent but it also makes sense in this case. I recently learned
 about this behavior in [http://lists.osgeo.org/pipermail/grass-
 dev/2014-December/072250.html discussion related to r63227 - in
 grass/trunk/scripts] ([http://osgeo-org.1560.x6.nabble.com/Re-GRASS-
 SVN-r63227-in-grass-trunk-scripts-d-correlate-d-out-file-d-rast-
 leg-d-redraw-d-shadedmap-d-t-td5175707.html nabble],
 [http://comments.gmane.org/gmane.comp.gis.grass.devel/61537 gmane]).
 I don't have any idea what should be the right behavior. It would be good
 to have different use cases to understand how it is actually used (or
 supposed to be used).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2509#comment:2>
