[GRASS-dev] GRASS 7 - Ubuntu package build problem on Launchpad
Ivan Minčík ivan.mincik at gmail.com
Mon Dec 8 01:12:16 PST 2014
On Mon, Dec 8, 2014 at 10:01 AM, Martin Landa <landa.martin at gmail.com>
wrote:
> Hi Ivan,
> 2014-12-08 7:16 GMT+01:00 Ivan Minčík <ivan.mincik at gmail.com>:
> > I did small investigation why Ubuntu package of GRASS 7 is failing to
> build
> > on Launchpad.
> first of all, thanks for you time.
> > The problem is caused by building single page documentation (make
> > htmldocs-single). This make command is also failing on my computer.
> Building
> > multi-page documentation (make htmldocs) is running without problem.
> These commands build API documentation [1]. I guess it's not needed
> for debian packaging, right? The user documentation [2] is build via
> default make command. I wonder there is attempt to build API manual
> for debian package. It doesn't make sense to me so much.
The same docs was build also in GRASS 6 packaging. It is a content of
'grass-dev-doc' package.
Removing it means loosing this package.
It is failing with meaningless error [1]:
*** [htmldocs-single] Error 2
The same error I get even if running by hand with 'make -d'
1 -
https://launchpadlibrarian.net/191285764/buildlog_ubuntu-precise-i386.grass70_7.0.0~ppa~2~revno-31311~ubuntu12.04.1_FAILEDTOBUILD.txt.gz
Ivan Minčík
ivan.mincik at gmail.com  GPG: 0x79529A1E
http://imincik.github.io/0x79529A1E.key
ivan.mincik at gista.sk     GPG: 0xD714B02C
http://imincik.github.io/0xD714B02C.key
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141208/23b1925c/attachment-0001.html>
