[GRASS-dev] [GRASS GIS] #2511: Starting GRASS in mapset which is not owned by the user
GRASS GIS trac at osgeo.org
Fri Dec 12 07:56:37 PST 2014
 Reporter:  wenzeslaus        |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  normal            |   Milestone:  7.1.0
Component:  Startup           |     Version:  unspecified
 Keywords:  access, database  |    Platform:  Unspecified
      Cpu:  Unspecified       |
 When GRASS is started in a mapset which is not owned by the current user,
 the error handling is not very nice.
 The following is behavior of 7.0 release branch approximately a month old
 (r62598, before introduction of exceptions to `*_command` functions).
 Error dialog after a start of GUI (note that the text and traceback does
 not fit together):
 Unable to get current geographic extent. Force quiting wxGUI. Please
 manually run g.region to fix the problem.
 Reason: 'version'
   File "/home/vpetras/dev/futures/grass70_release/dist.x86_64-unknown-
 linux-gnu/gui/wxpython/lmgr/frame.py", line 93, in __init__
     grassVersion = grass.version()['version']
 KeyError: 'version'
 Terminal shows GRASS prompt and contains at that point "permission denied"
 and "unable to get GRASS version" errors.
 ERROR: MAPSET PERMANENT - permission denied
 Unable to get GRASS version
 GRASS_INFO_ERROR(28313,1): MAPSET PERMANENT - permission denied
 GRASS_INFO_END(28313,1)
 GRASS_INFO_ERROR(28314,1): MAPSET PERMANENT - permission denied
 GRASS_INFO_END(28314,1)
 GRASS_INFO_ERROR(28317,1): MAPSET PERMANENT - permission denied
 GRASS_INFO_END(28317,1)
 Finally, after clicking OK in the GUI error dialog, GUI ends with the
 following traceback:
 linux-gnu/gui/wxpython/wxgui.py", line 140, in <module>
     sys.exit(main())
 linux-gnu/gui/wxpython/wxgui.py", line 133, in main
     app = GMApp(workspaceFile)
 linux-gnu/gui/wxpython/wxgui.py", line 48, in __init__
     wx.App.__init__(self, False)
   File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py",
 line 7981, in __init__
     self._BootstrapApp()
 line 7555, in _BootstrapApp
     return _core_.PyApp__BootstrapApp(*args, **kwargs)
 linux-gnu/gui/wxpython/wxgui.py", line 82, in OnInit
     workspace = self.workspaceFile)
 linux-gnu/gui/wxpython/lmgr/frame.py", line 221, in __init__
     self.NewDisplay(show = False)
 linux-gnu/gui/wxpython/lmgr/frame.py", line 1727, in NewDisplay
     showMapDisplay = show)
 linux-gnu/gui/wxpython/lmgr/layertree.py", line 176, in __init__
     Map = self.Map)
 linux-gnu/gui/wxpython/mapdisp/frame.py", line 153, in __init__
     self.statusbarManager.Update()
 linux-gnu/gui/wxpython/mapdisp/statusbar.py", line 227, in Update
     item.Update() # mask, render
 linux-gnu/gui/wxpython/mapdisp/statusbar.py", line 810, in Update
     mapset = grass.gisenv()['MAPSET'])['name']:
 KeyError: 'name'
 You can run commands in the system command line but you get "permission
 denied".
 g.list rast -p
 However, this is not completely true because in my case, I can write
 there, I just don't own it, so I think the message should be more precise
 and contain information about different owner, e.g. "permission denied,
 you are not a owner of this mapset". Maybe even better would be:
 ERROR: Permission denied for mapset <%s> because you are not the owner
 In trunk approximately 2 weeks old (r62885), GUI does not start but the
 session in command line still starts. The error is coming from some call
 of `tempfile()` from `render.py`.
   File "/opt/src/grass-trunk/dist.x86_64-unknown-linux-
 gnu/gui/wxpython/wxgui.py", line 36, in <module>
     from lmgr.frame import GMFrame
 gnu/gui/wxpython/lmgr/frame.py", line 50, in <module>
     from lmgr.layertree        import LayerTree, LMIcons
 gnu/gui/wxpython/lmgr/layertree.py", line 37, in <module>
     from mapdisp.frame        import MapFrame
 gnu/gui/wxpython/mapdisp/frame.py", line 65, in <module>
     class MapFrame(SingleMapFrame):
 gnu/gui/wxpython/mapdisp/frame.py", line 71, in MapFrame
     page = None, Map = Map(), auimgr = None, name = 'MapWindow',
 **kwargs):
 gnu/gui/wxpython/core/render.py", line 408, in __init__
     self.mapfile = grass.tempfile(create = False) + '.ppm'
 gnu/etc/python/grass/script/core.py", line 702, in tempfile
     return read_command("g.tempfile", flags=flags,
 pid=os.getpid()).strip()
 gnu/etc/python/grass/script/core.py", line 425, in read_command
     return handle_errors(returncode, stdout, args, kwargs)
 gnu/etc/python/grass/script/core.py", line 308, in handle_errors
     returncode=returncode)
 grass.exceptions.CalledModuleError: Module run None ['g.tempfile', '-d',
 'pid=27302'] ended with error
 Process ended with non-zero return code 1. See errors in the (error)
 output.
 Latest trunk (r63504) has different error of same sort, `list_strings()`
 fails when called from `prompt.py`.
 GRASS_INFO_END(27234,1)
   File "/home/vpetras/dev/grass/trunk/dist.x86_64-unknown-linux-
 gnu/gui/wxpython/wxgui.py", line 142, in <module>
     sys.exit(main())
 gnu/gui/wxpython/wxgui.py", line 134, in main
 gnu/gui/wxpython/wxgui.py", line 49, in __init__
 gnu/gui/wxpython/wxgui.py", line 83, in OnInit
 gnu/gui/wxpython/lmgr/frame.py", line 135, in __init__
     self.notebook  = self._createNoteBook()
 gnu/gui/wxpython/lmgr/frame.py", line 301, in _createNoteBook
     gcstyle = GC_PROMPT)
 gnu/gui/wxpython/gui_core/goutput.py", line 104, in __init__
     self.cmdPrompt = GPromptSTC(parent=self, menuModel=self._menuModel)
 gnu/gui/wxpython/gui_core/prompt.py", line 137, in __init__
     GPrompt.__init__(self, parent = parent, menuModel = menuModel)
 gnu/gui/wxpython/gui_core/prompt.py", line 56, in __init__
     self.mapList    = self._getListOfMaps()
 gnu/gui/wxpython/gui_core/prompt.py", line 96, in _getListOfMaps
     result['raster'] = grass.list_strings('raster')
 gnu/etc/python/grass/script/core.py", line 1108, in list_strings
     mapset=mapset).splitlines():
 grass.exceptions.CalledModuleError: Module run None ['g.list', '--q',
 '-m', 'type=rast'] ended with error
 output.
 I think there is not point in fixing or improving any of these errors. The
 GRASS session should not start when in text mode and the startup/welcome
 window should not allow you to start in mapset where you cannot write
 (according to GRASS rules and settings). I don't know what is the right
 way of checking this? Is there a module for it? Or should we fix it in a
 different way?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2511>
