[GRASS-dev] [GRASS GIS] #2409: last call for options keys consolidation
GRASS GIS trac at osgeo.org
Wed Dec 17 07:10:35 PST 2014
 Reporter:  martinl               |       Owner:  grass-dev@…
     Type:  task                  |      Status:  new
 Priority:  blocker               |   Milestone:  7.0.0
Component:  Default               |     Version:  unspecified
 Keywords:  standardized options  |    Platform:  Unspecified
      Cpu:  Unspecified           |
Comment(by hcho):
 Replying to [comment:130 martinl]:
 > Replying to [comment:129 martinl]:
 > > I think that it would be useful to modify parser to understand also
 `rast` (`rast3d is OK because '_' is treated as word separator).
 > attachment:raster_3d.diff
 I'm generally against adding special cases in the code. IMHO, if the user
 types `rast`, s/he means `raster` not `raster_3d` and it shouldn't be
 ambiguous. Currently, the parser would stop with a parameter ambiguous
 error. I think it would be more useful to modify the parser such that it
 takes the shortest unambiguous parameter with no further underscores.
 For example,
 * modules with parameters `raster_map=` and `raster_3d=`: `rast` and
 `raster_` would be ambiguous.
 * modules with parameters `raster=` and `raster_3d=`: `r` and `rast` would
 match with `raster=` and `r3` and `rast3` with `raster_3d=`
 * modules with parameters `raster_map=` and `raster_map_2=`: `rast`
 ambiguous, `rmap` for `raster_map=` and `rmap2` for `raster_map_2=`
 * modules with parameters `raster_map=` and `raster_map2=`: `rast`
 ambiguous, `rmap` for `raster_map=` and `rmap2` for `raster_map2=`
 I'm not sure if I was clear enough here.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:131>
