[GRASS-dev] [GRASS GIS] #2403: cairo driver fails to create surface
GRASS GIS trac at osgeo.org
Thu Dec 18 04:34:00 PST 2014
 Reporter:  martinl                     |       Owner:  martinl
     Type:  defect                      |      Status:  assigned
 Priority:  major                       |   Milestone:  7.0.0
Component:  Display                     |     Version:  unspecified
 Keywords:  cairo, resolution, surface  |    Platform:  Linux
      Cpu:  x86-64                      |
Comment(by glynn):
 Replying to [comment:8 martinl]:
 > Could you please review attachment:cairo_down_sampling.diff which do
 down-sampling for Cairo in similar as already does PNG driver?
 The main issue was that it neglected the inner Y loop when up-scaling.
 r63582 makes the cairo driver behave almost identically to the PNG driver.
 For reasons which I've been unable to determine so far, the result is one
 destination pixel wider than with the PNG driver.
 Ultimately, the code should be modified to use an intermediate surface
 which has the same dimensions as the destination rectangle, to avoid the
 overhead of copying the (empty) borders.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2403#comment:9>
