[GRASS-dev] [GRASS GIS] #2409: last call for options keys consolidation
GRASS GIS trac at osgeo.org
Thu Dec 18 08:58:53 PST 2014
 Reporter:  martinl               |       Owner:  grass-dev@…
     Type:  task                  |      Status:  new
 Priority:  blocker               |   Milestone:  7.0.0
Component:  Default               |     Version:  unspecified
 Keywords:  standardized options  |    Platform:  Unspecified
      Cpu:  Unspecified           |
Comment(by hcho):
 Replying to [comment:133 glynn]:
 > Replying to [comment:131 hcho]:
 > > * modules with parameters `raster_map=` and `raster_map_2=`: `rast`
 ambiguous, `rmap` for `raster_map=` and `rmap2` for `raster_map_2=`
 > > * modules with parameters `raster_map=` and `raster_map2=`: `rast`
 ambiguous, `rmap` for `raster_map=` and `rmap2` for `raster_map2=`
 > > I'm not sure if I was clear enough here.
 > You're suggesting that the abbreviation must include some part of the
 last word of the option name? Or that it must include the last character?
 I.e. is rm= ambiguous?
 No, not the last word of the option name. You cannot skip any words
 separated by an underscore. rm= is not ambiguous in this case because the
 shortest option name that matches rm= is raster_map=. If one wants
 raster_map2=, use rmap2=, not rm2= (no abbreviation inside a word).
 > The main problems I foresee with that are
 >  * The last word (or an abbreviation of it) might match some earlier
 portion of the option name, meaning that the user intended to specify
 (part of) the last word but the characters were matched against an earlier
 portion.
 I'm not talking about skipping words and using the last word, so this is
 not the case.
 >  * It's possible for a string to match the last word of multiple
 options. E.g. given options raster_map and raster_2_map, rmap would match
 both equally.
 rmap= would match raster_map= "only" because you cannot skip 2.
 Hope I'm clearer now.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:136>
