[GRASS-dev] [GRASS GIS] #2409: last call for options keys consolidation
GRASS GIS trac at osgeo.org
Mon Dec 22 14:19:50 PST 2014
 Reporter:  martinl               |       Owner:  grass-dev@…
     Type:  task                  |      Status:  new
 Priority:  blocker               |   Milestone:  7.0.0
Component:  Default               |     Version:  unspecified
 Keywords:  standardized options  |    Platform:  Unspecified
      Cpu:  Unspecified           |
Comment(by hellik):
 Replying to [comment:154 martinl]:
 > Replying to [comment:152 martinl]:
 > > For those who would like to help with our effort, please check
 attachment:module_params_overview-2014-12-12.ods and inform us about
 remaining parameter
 > sorry the correct file is
 attachment:module_params_overview-2014-12-22.ods !!!
 maybe some candidates?
 stream_rast     Name for output raster map with unique stream ids
 stream_vect     Name for output vector map with unique stream ids
 transmissivity_singleway        Name of single-way transmissivity raster
 map [0.0-1.0]
 transmissivitysingleway Name of the single-way atmospheric
 transmissivitymap [-]
 walk_coeff      Coefficients for walking energy formula parameters a,b,c,d
 transport_coeff Name of transport capacity coefficient raster map [s]
 topidxclass     Topographic index class
 topidxstats     Name of topographic index statistics file
 tiledimension   The dimensions of the tiles used in the output raster3d
 map (XxYxZ or default: 16x16x8)
 tilesize        The maximum tile size in kilo bytes. Default is 32KB.
 swatershed      Name for output sink-watershed raster map
 start_rast      Name of starting raster points map
 stab    Set the flow stabilizing scheme (full or exponential upwinding).
 staend  The user defined values that indicate start, intermediate and end
 status in the indicator output space time raster dataset
 sourceproj      Source projection
 sourcescale     Conversion factor from units to meters in source
 projection
 soilheatflux    Name of instantaneous soil heat flux raster map [W/m2]
                                 Name of soil heat flux raster map [W/m2]
 soilmoisture    Name for output root zone soil moisture raster map
 slope_tol       Slope tolerance that defines a 'flat' surface (degrees)
 segmax  Maximum length of segment on network
                 Maximum number of points in a segment
 savehistory     Text file in which to save history
 savesettings    Name for output file where to save current settings
 rgbmaps Three (R,G,B) 3D raster maps to create RGB values
 [redmap,greenmap,bluemap]
                 Three (r,g,b) raster maps to create RGB values
 productname     Name of MODIS product type
 pclay   Name of soil clay fraction raster map [0.0-1.0]
 pcurvature      Name for output profile curvature map (or fxx)
                 Name for output profile curvature raster map
 outtopidxstats  Name for output topographic index statistics file
 nwalkers        Number of walkers
                         Number of walkers, default is twice the number of
 cells
 num_partitions  Read the input files in this number of chunks
 npartitions     Number of partitions
 ncolumn Node cost column
                 Node cost column (number)
 min_area        Minimum size of area to be imported (square units)
 min_size        Minimum number of pixels in a class
 min_slope       Minimum slope value (in percent) for which aspect is
 computed
 mcurvature      Name for output mean curvature 3D raster map
                         Name for output mean curvature map (or fxy)
                         Name for output mean curvature raster map
 loadhistory     Text file from which to load history
 loadsettings    Name of input file to read settings from
 localutctime    Name of time of satellite overpass raster map [local time
 in UTC]
 insol_time      Output insolation time raster map [h] (mode 2 only)
 infil   Name of runoff infiltration rate raster map [mm/hr]
 infil_value     Runoff infiltration rate unique value [mm/hr]
 infile  Input file with one input raster map name and data point position
 per line, field separator between name and sample point is |
 init_time       Initial time for current simulation (0) (min)
 gcurvature      Name for output Gaussian curvature 3D raster map
 beam_rad        Output beam irradiance [W.m-2] (mode 1) or irradiation
 raster map [Wh.m-2.day-1] (mode 2)
 afcolumn        Arc forward/both direction(s) cost column (number)
 acolumn Arcs' cost column (for both directions)
 abcolumn        Arc backward direction cost column (number)
                         EXPERIMENTAL: Arc backward direction cost column
 (number)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:158>
