[GRASS-dev] [GRASS GIS] #2513: v.colors freezes using the pg driver and attr
GRASS GIS trac at osgeo.org
Mon Dec 22 18:37:15 PST 2014
 Reporter:  jamesp670                |       Owner:  grass-dev@…
     Type:  defect                   |      Status:  new
 Priority:  normal                   |   Milestone:  7.0.0
Component:  Database                 |     Version:  svn-trunk
 Keywords:  freeze in G_fatal_error  |    Platform:  Linux
      Cpu:  x86-64                   |
 Hi Grass Devs,
 You've got a big fan in me.  I acknowledged GRASS on my AGU (see agu.org)
 poster this year and I'll make sure it's a cite next year.
 I have a bug report.  This is getting complex and perhaps you can help?
 The setup:
 My uname output:
 : GRASS 7.0.0svn (rlis-master-for-seven):~ > uname -a
 : Linux login.cluster 2.6.32-431.17.1.el6.x86_64 #1 SMP Wed May 7 23:32:49
 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
 I built grass from source, using primarily deps supplied by
    : yum install http://yum.postgresql.org/9.3/redhat/rhel-6-x86_64/\
    : pgdg-redhat93-9.3-1.noarch.rpm
 The build is painless.  GRASS works great, except for this bug.
 I run GRASS v.colors to obtain a color map for TIGER census, as in:
 : GRASS 7.0.0svn (rlis-master-for-seven):~ > v.colors --verbose
 map=tract2010censusdp1_clipped_02 column=popden10 layer=1
 rgb_column=GRASSRGB color=grey
 What I expect:
 GRASSRGB column is created and populated with greyscale values.
 What happens instead, is that v.colors freezes.  Specifically, I see this
 sequence:
 : Option <column> given, assuming <use=attr>...
 : Converting color rules into categories...
 : Writing color rules...
 : DBMI-PostgreSQL driver error:
 : Unable to execute:
 : ALTER TABLE tract2010censusdp1_clipped_02 ADD COLUMN GRASSRGB
 VARCHAR(11)
 : ERROR:  column "grassrgb" of relation "tract2010censusdp1_clipped_02"
 already exists
 VARCHAR(11)
 already exists
 : ERROR: Unable to add column <GRASSRGB> to table
 :        <tract2010censusdp1_clipped_02>
 : no database is open
 :   C-c C-c
 Where the C-c C-c is, I am tapping C-c to break the task, which is
 blatently frozen.
 I've debugged it.  The sequence of events is:
 : print "no database is open"
 : db_shutdown_driver(driver=00661C40)
 : doing waitpid(pid=1583)
 : [freeze]
 During the freeze, proc 1583 is still running, and it's a db/pg process.
 If I "kill 1583", the v.colors job ends immediately with no additional
 output,
 as in
 : [I kill the db/pg process by hand]
 I've tried v.colors in the trunk and release SVN branches.  The layer is
 fine,
 I can query it, view attributes just fine.  db.test output looks fine.
 It's
 100% reproducable.
 I build from source, debug with gdb, insert print statements.  That's what
 got
 me this far, but now this IPC with the grass-7.0.0svn/driver/db/pg process
 is
 getting pretty complex.  If I had to hazard a guess, I'd say that closing
 the
 communication FILEs in shutdown.c should cause the db/pg process to end.
 It
 is not for some reason.  That then also begs the question of why the
 shutdown
 is called before the colors are written at all.  The stack is:
 : (gdb) where
 : ,#0  0x0000003ab72ac8ce in waitpid () from /lib64/libc.so.6
 : ,#1  0x00002aaaab17f3ad in G_wait (i_pid=28458) at spawn.c:981
 : ,#2  0x00002aaaaad37348 in db_shutdown_driver (driver=0x661ec0) at
 shutdown.c:59
 : ,#3  0x00002aaaaad35e60 in error_handler_driver (p=0x661ec0) at
 handler.c:24
 : ,#4  0x00002aaaab1630ad in G__call_error_handlers () at handler.c:108
 : ,#5  0x00002aaaab15ee93 in G_fatal_error (
 :     msg=0x405368 "Unable to add column <%s> to table <%s>") at
 error.c:176
 : ,#6  0x00000000004042b1 in write_rgb_values (Map=0x7fffffffcfb0,
 layer=1,
 :     column_name=0x654830 "GRASSRGB", colors=0x7fffffffce90) at
 write_rgb.c:37
 : ,#7  0x0000000000402f83 in main (argc=7, argv=0x7fffffffd988) at
 main.c:350
 If I delete grassrgb by hand, v.colors does return neatly and works great,
 as in:
 : psql (9.3.5)
 : => alter table tract2010censusdp1_clipped_02 drop column grassrgb;
 : ALTER TABLE
 then
 h: Option <column> given, assuming <use=attr>...
 : Column <GRASSRGB> added to table <tract2010censusdp1_clipped_02>
 : Color table for vector map <tract2010censusdp1_clipped_02 at PERMANENT> set
 to
 : 'grey'
 The content of GRASSRGB looks fine after that.
 Removing the color table using -r before running doesn't work, I get
 : GRASS 7.0.0svn (rlis-master-for-seven):~ > v.colors -r
 map=tract2010censusdp1_clipped_02 rgb_column=GRASSRGB
 : WARNING: Color table of vector map <tract2010censusdp1_clipped_02> not
 :          found
 rgb_column=GRASSRGB color=bgyr
 : [freeze]
 I obviously don't understand the difference between the color table and
 the rgb_column.  v.colors seems to
 lack the usual --overwrite.
 So I have a workaround: remove the column by manual sql entry before
 running
 v.colors.  The freeze is obviously a bug, and there seems to be a lack of
 clarity RE: the lack of --overwrite and the use of -r.
 How you can reproduce this at home:
 1. Open http://rlisdiscovery.oregonmetro.gov/
 2. CLick on "Download" for 2000 Block Groups.
 3. Save it into ~/tmp
 4. unzip blockgrp2000.zip
 5. grass70 -gui
 6. Location Wizard
 7. Project Location: rlus-bug-report
 8. Read projection ... data file
 9. Georef file: blockgrp2000.shp
 10. Do *not* Import the data (although that is a nice grass 7 touch
 there!)
 11. start grass.
 12. db.connect driver=pg database="host=myhost,dbname=mydb"
     [substitute your database of course]
 13. v.in.ogr dsn=/home/powellj/tmp/blockgrp2000.shp output=blockgrp2000
     (4385 primitives imported in about a minute).
 14. v.colors --verbose map=blockgrp2000 column=pop08 layer=1
                 [works great, finishes in < 1s]
 15. Repeat step 14.  It freezes immediately, reading "no database is
 open".
Ticket URL: <http://trac.osgeo.org/grass/ticket/2513>
