[GRASS-dev] [GRASS GIS] #2409: last call for options keys consolidation
GRASS GIS trac at osgeo.org
Wed Dec 24 07:03:58 PST 2014
 Reporter:  martinl               |       Owner:  grass-dev@…
     Type:  task                  |      Status:  new
 Priority:  blocker               |   Milestone:  7.0.0
Component:  Default               |     Version:  unspecified
 Keywords:  standardized options  |    Platform:  Unspecified
      Cpu:  Unspecified           |
Comment(by martinl):
 Replying to [comment:163 martinl]:
 > > ncolumn     Node cost column
 > >             Node cost column (number)
 > This is more significant issue, all of v.net modules uses various
 shortened options
 > > afcolumn    Arc forward/both direction(s) cost column (number)
 > > acolumn     Arcs' cost column (for both directions)
 > > abcolumn    Arc backward direction cost column (number)
 > >                     EXPERIMENTAL: Arc backward direction cost column
 (number)
 > see my note about `v.net` modules above
 I went though v.net modules and renamed
 alayer -> arc_layer
 nlayer -> node_layer
 type -> arc_type
 ccats -> center_cats
 ncolumn -> node_column
 afcolumn -> arc_column
 abcolumn -> arc_backward_column
 tcats -> terminal_cats
 nsp -> npoints
 coordinate -> coordinates
 vis -> visibility
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:164>
