[GRASS-dev] Few notes to GRASS 7 Launchpad builds
Ivan Mincik ivan.mincik at gmail.com
Thu Dec 25 22:31:01 PST 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi Martin,
On 25.12.2014 10:57, Martin Landa wrote:
> Dear Ivan,
> 2014-12-09 11:30 GMT+01:00 Ivan Mincik <ivan.mincik at gmail.com>:
>> 1. Current GRASS package version suffix (revno) is currently made
>> from Bazaar import version, which is meaningless for users (for
>> example: 7.0.0~ppa~2~revno-31311~ubuntu12.04.1 - 31311 is that
>> Bazaar version) I would propose to update to 0.4 version of
>> Launchpad build recipes and change {revno} variable to
>> {svn-revno} which will be substituted by GRASS SVN revision
>> number rather than meaningless Bazaar import revision as it was
>> now. SVN version is much higher value than BZR, so no problems
>> with upgrades
>> Also, I propose to update little bit version format to latest
>> standards [1][2].
>> Proposed recipe: # bzr-builder format 0.4 deb-version
>> 7.0.0+1svn{svn-revno} lp:grass/7.0 nest debianfiles
>> lp:~grass/grass/grass70_release_debian debian
> I can try to do it recently I became member of the Launchpad team
> [1]. Do I need administrator status for this job?
You do not need to be administrator to create a recipe - it is
possible to create a recipe as a user outside of GRASS team (which
will be listed on GRASS page), which will place debs to creator's
personal repository instead of GRASS. The same is with builds - anyone
can request a build using recipe from GRASS, which will generate debs
to his personal repository.
But surely you have to be administrator to update recipe created by
Rashad.
>> 2. GRASS Stable PPA depends on both ubuntugis-stable and
>> ubuntugis-unstable PPA repositories which can produce unexpected
>> results. I am proposing to choose only one of them.
> This can be changed also by administrator only, I guess?
I guess too :)
>> 3. GRASS 7 builds should be fixed now (fix is already loaded in
>> bzr). It is needed to request for build.
Martin, the fix was made by You. I was just trying to speed up bzr
synchronization and make a test build.
Ivan Minčík
ivan.mincik at gmail.com  GPG: 0x79529A1E
http://imincik.github.io/0x79529A1E.key
ivan.mincik at gista.sk     GPG: 0xD714B02C
http://imincik.github.io/0xD714B02C.key
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
iQEcBAEBAgAGBQJUnQClAAoJEPfdLsR5UpoepE8H/R4JEMVWyhwLT0xcpMCFYmX1
2J/As3AIPFb9Oju6B8Hwmf4qaG858/cHsEEBz4q+/JVl3hKl9S3K67+dY4OPnW/1
EbrhhKqgg7oHMtVd2nsDaMvaXYT1CJOLmbUEqGJ0IswlSZpIt8oTIYPaRILVTz+Y
jeCJG/7ZPG67ztpBqIcXQTEp7RmQTei4dEdSXx/iKFaWD8A/yj3XbmUyJs3T3yxs
aj7czMoJQ56AGubpdiNCnQ+RP//noaA/40HiDsI87jLke/KJowtfc1j4UY+6tG3Y
tENJeYBou62b+sCFbAjPAmZ9Ip6rQYQq/2A6IgrAfJaKUFD4l8bBXaEebMwC6Gc=
=uF+X
-----END PGP SIGNATURE-----
