[GRASS-dev] [GRASS GIS] #2505: v.build.polylines options aren't working
GRASS GIS trac at osgeo.org
Sat Dec 27 06:53:58 PST 2014
 Reporter:  hellik             |       Owner:  grass-dev@…
     Type:  defect             |      Status:  new
 Priority:  major              |   Milestone:  7.0.0
Component:  Vector             |     Version:  svn-releasebranch70
 Keywords:  v.build.polylines  |    Platform:  All
      Cpu:  Unspecified        |
Changes (by hellik):
  * priority:  critical => major
Comment:
 Replying to [comment:2 neteler]:
 > Replying to [comment:1 mmetz]:
 > > Replying to [ticket:2505 hellik]:
 > > `cats=no` was indeed not working, fixed in r63321,2 (trunk, relbr70).
 confirmed cats=no is working now
 > Should this go also into GRASS 6?
 > > `v.build.polylines` is indeed copying all attribute tables as is from
 input to output, but the categories are processed according to the cats
 option. This means that the attribute table(s) can contain spurious
 entries that do not match any output feature. Other (not all) modules also
 copy attribute tables from input to output as is, without filtering.
 Usually, this does not harm and is not even noticeable.
 above should go into the manual.
 > Is this ticket solved?
 downgrading priority; closing ticket when manual is extended.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2505#comment:3>
