[GRASS-dev] [GRASS GIS] #2516: r.stream.distance elevation above streams produces unexpected null values
GRASS GIS trac at osgeo.org
Sun Dec 28 12:21:47 PST 2014
 Reporter:  madi                        |       Owner:  grass-dev@…
     Type:  defect                      |      Status:  new
 Priority:  normal                      |   Milestone:  7.1.0
Component:  Raster                      |     Version:  svn-trunk
 Keywords:  r.stream,r.stream.distance  |    Platform:  Unspecified
      Cpu:  Unspecified                 |
Comment(by madi):
 Replying to [comment:1 hellik]:
 > Replying to [ticket:2516 madi]:
 > > elev2stream map has several null values.
 > where are the null values?
 > I know only the null values at the border of the DEM (red in the
 screenshot) where no stream information is available.
 Hi, in my case null values are scattered all over the map, see attached
 screenshot (the large spots however are water). I realised that the
 command line i actually gave is slightly different from the one i posted
 earlier (if matters) and is:
 r.stream.distance --verbose stream_rast=stream1500 direction=drainage
 elevation=dem method=downstream distance=dist2stream_2
 difference=elev2stream_2 memory=2000
 Thanks
 madi
Ticket URL: <https://trac.osgeo.org/grass/ticket/2516#comment:2>
