[GRASS-dev] [GRASS-SVN] r61255 - grass/trunk/gui/wxpython/core
Vaclav Petras wenzeslaus at gmail.com
Mon Dec 29 05:14:32 PST 2014
On Tue, Oct 14, 2014 at 10:24 PM, Vaclav Petras <wenzeslaus at gmail.com>
wrote:
> On Mon, Jul 14, 2014 at 3:03 PM, <svn_grass at osgeo.org> wrote:
>> Author: wenzeslaus
>> Date: 2014-07-14 12:03:34 -0700 (Mon, 14 Jul 2014)
>> New Revision: 61255
>> Modified:
>>    grass/trunk/gui/wxpython/core/utils.py
>> Log:
>> wxGUI/core: use gray always, sync purple with lib/gis/color_str.c
>> although it is probably wrong
>> before: depending on dict ordering gray or grey was used, (un)checking
>> Transparent in GUI caused switching from gray to grey
>> purple: accoring to Wikipedia it is different from violet and was
>> correctly defined in the GUI before but this was not the same as in library
>> Modified: grass/trunk/gui/wxpython/core/utils.py
>> --- grass/trunk/gui/wxpython/core/utils.py      2014-07-14 18:27:46 UTC
>> (rev 61254)
>> +++ grass/trunk/gui/wxpython/core/utils.py      2014-07-14 19:03:34 UTC
>> (rev 61255)
>> @@ -945,29 +945,37 @@
>>      # update path
>>      if addonPath not in os.environ['PATH']:
>>          os.environ['PATH'] = addonPath + os.pathsep + os.environ['PATH']
>> -# From lib/gis/col_str.c, except purple which is mentioned
>> -# there but not given RGB values
>> +# predefined colors and their names
>> +# must be in sync with lib/gis/color_str.c
>>  str2rgb = {'aqua': (100, 128, 255),
>>             'black': (0, 0, 0),
>>             'blue': (0, 0, 255),
>>             'brown': (180, 77, 25),
>>             'cyan': (0, 255, 255),
>>             'gray': (128, 128, 128),
>> +           'grey': (128, 128, 128),
>>             'green': (0, 255, 0),
>> -           'grey': (128, 128, 128),
>>             'indigo': (0, 128, 255),
>>             'magenta': (255, 0, 255),
>>             'orange': (255, 128, 0),
>> -           'purple': (128, 0, 128),
>>             'red': (255, 0, 0),
>>             'violet': (128, 0, 255),
>> +           'purple': (128, 0, 255),
>>             'white': (255, 255, 255),
>>             'yellow': (255, 255, 0)}
>>  rgb2str = {}
>> -for (s,r) in str2rgb.items():
>> -    rgb2str[ r ] = s
>> +for (s, r) in str2rgb.items():
>> +    rgb2str[r] = s
>> +# ensure that gray value has 'gray' string and not 'grey'
>> +rgb2str[str2rgb['gray']] = 'gray'
>> +# purple is defined as nickname for violet in lib/gis
>> +# (although Wikipedia says that purple is (128, 0, 128))
>> +# we will prefer the defined color, not nickname
>> +rgb2str[str2rgb['violet']] = 'violet'
>> Has somebody some idea about the purple and violet color definitions (in
> lib, formerly in GUI, on Wikipedia) before backport to release branch 7.0?
> I guess now is the time to change it.
> Wikipedia
> Violet is (127, 0, 255)
> Purple is (128, 0, 128)
> http://en.wikipedia.org/wiki/Purple
> http://en.wikipedia.org/wiki/Violet_%28color%29
> GRASS GIS
> Violet (128, 0, 255)
> Purple is the same as Violet (in the same manner as Grey is Gray)
> http://trac.osgeo.org/grass/browser/grass/trunk/lib/gis/color_str.c
> http://trac.osgeo.org/grass/browser/grass/trunk/include/colors.h
> http://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/core/utils.py#L948
I cannot go through this again but perhaps somebody can have a look.
Backport this one and change the definitions in library. Or, I would be
fine with saying that this is known issue and fix it in 7.1.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141229/7b117e01/attachment.html>
