[GRASS-dev] Is grass70b4 compiling on FreeBSD ?
Markus Neteler neteler at osgeo.org
Tue Dec 30 05:42:45 PST 2014
On Tue, Dec 30, 2014 at 1:31 AM, Fábio Dias <fabio.dias at gmail.com> wrote:
> Hi,
> So, I started with a fresh checkout (from the URL you told me to switch to).
ok, fine.
> The full log is on http://pastebin.com/2n9vswif
> The "important" part, afaik, is :
> /usr/home/diasf/releasebranch_7_0/dist.x86_64-unknown-freebsd10.1/lib/libgrass_gis.7.0.0svn.so:
> undefined reference to `libiconv'
> undefined reference to `libiconv_close'
> undefined reference to `libiconv_open'
> So I've tried with --with-iconv on the configure, not that this option
> exist... Then I manually changed a Makefile, on one of the directories
> with error. Added -liconv to he LIBES var, then the make worked.
Ok. You could enable that globally here:
include/Make/Platform.make
which is autogenerated. Please take a look at
config.log
and search therein for libiconv. It will contain the error why it wasn't found.
Markus
