[GRASS-dev] GRASS 7 - Ubuntu package build problem on Launchpad
Markus Neteler neteler at osgeo.org
Tue Dec 30 08:17:11 PST 2014
On Tue, Dec 30, 2014 at 3:58 PM, Ivan Mincik <ivan.mincik at gmail.com> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> On 12/30/2014 03:29 PM, Markus Neteler wrote:
>> On Tue, Dec 30, 2014 at 3:13 PM, Ivan Mincik <ivan.mincik at gmail.com>
>> wrote:
>>> -----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
>>> On 30.12.2014 15:00, Markus Neteler wrote:
>> So, when running "configure" before compilation, the version number is
>> picked up: In "configure" line 1281 and later, it executes
>> svnversion
>> which reports the SVN revision number.  Could you please execute
>> "svnversion" in your GRASS 7.0.svn source code main directory?
> Debian builder can't execute 'svnversion' because it has no access to '.svn'
> files and no 'svn' software is installed in build chroot.
Strange, the .svn/ directory is part of the GRASS source code.
> So this can be a root of the problem.
Yes, indeed.
> Was there any significant change of version assignment between 6 and 7 ?
Yes.
> Anyway, it seems to be a packaging problem rather a problem in GRASS as I
> originally expected.
Yes, a packaging problem which hinders to run GRASS properly on Ubuntu.
On all other distros I know there is no such issue, so we need to
implement a workaround in case of absence of "svnversion". In my
compiled Fedora package I can extract it also from here:
grep SVN dist.x86_64-unknown-linux-gnu/include/Make/Platform.make
GRASS_VERSION_SVN   = 63869M
Markus
> Ivan Minčík
> ivan.mincik at gmail.com   GPG: 0x79529A1E  http://imincik.github.io/0x79529A1E.key
> ivan.mincik at gista.sk    GPG: 0xD714B02C  http://imincik.github.io/0xD714B02C.key
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.11 (GNU/Linux)
> Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
> iQEcBAEBAgAGBQJUor2gAAoJEPfdLsR5UpoeeyoH/2lBNKT4HmtTOxly6u05sHrH
> BQoDMP9iBkS5fAh5dImoZ17Q3w7qNZk12xjHyGP7KVVS4sn8czZxBAurV4gxFYvG
> qcpneRP146IyQhrv0HaNF1njn6ulMK/2HwMUVNsUpBsC/u7Hy3gUsnPskQqzm0oS
> 9E0yKan4OnkCk1K8c5Pfqw2ziV/CKBIYhLk/5r7OnQHgfo/+kAAQHCFe52lbqV/6
> 3KIroPiZ02vIMyMaA2cfwi8UWMgwXhjVpOOx44X6OUjrSvv0pNwe8ZKmqiuRYJor
> mxRDlsyTYGjY6QBwbbENMCV7v31TXF5QCP2f/25bHyxZ05orGzX97guMk03Tvf4=
> =8Xpj
> -----END PGP SIGNATURE-----
