[GRASS-dev] [SPAM?] Re: anyone compiled GRASS 7 on Mac Yosemite?
Michael Barton Michael.Barton at asu.edu
Tue Dec 30 12:49:10 PST 2014
Thanks. The versions I now have posted work fine with Yosemite. But I have not yet compiled under Yosemite.
I have a couple of questions:
What is: export VERSIONER_PYTHON_PREFER_32_BIT=yes?
Also, is the SQLite problem something to do with Yosemite or something else?
I’ve also tried with wxPython 3 but it looks bad. So I’m still sticking with 2.8 (which is why we need the 32bit Python).
Here is what I do before compiling
# This is for creating a distributable binary that is backward compatible to OSX 10.7
export MACOSX_DEPLOYMENT_TARGET=10.7
# This stuff is for making sure that it compiles using 32 bit Python
export PATH="/Applications/python/bin32:/System/Library/Frameworks/Python.framework/Versions/2.7/bin:$PATH”
# This is what I do for PROJ
export NAD2BIN=/Library/Frameworks/PROJ.framework/Programs/nad2bin
# This is (IIRC) for LAS tools compiling
export CXX=g++
For the broken xml stuff, I’ve just saved versions of menudata.xml. and module_tree_menudata.xml. I drop these into the proper places before making a binary. Can I just run make from the source root from within GRASS to get the same thing?
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Dec 30, 2014, at 1:36 PM, Helena Mitasova <hmitaso at ncsu.edu> wrote:
> Michael,
> Anna compiled it for me.
> Below is the configure and some notes. We had to run make for wxGUI from within GRASS and the vector attribute tables do not work
> for me at the moment due to sqlite problems - we ran out of time to solve it.
> We also used wxPython carbon 3 to see what kind of problems it would have - so some of the GUI panels are cut off so use 2.8
> But otherwise it works great so it is worth doing - if you could provide GRASS7 binaries for yosemite that would be fantastic,
> Anna is away but I have the machine with me so I can help or at least test.
> Thanks for looking into it,
> Helena
> here are our notes:
> ./configure \
> --with-proj \
> --with-x \
> --with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include \
> --with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib \
> --with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj \
> --with-gdal=/Library/Frameworks/GDAL.Framework/Programs/gdal-config \
> --with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include \
> --with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib \
> --with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include \
> --with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib \
> --with-opengl=aqua \
> --without-fftw \
> --with-cairo --with-cairo-includes=/Library/Frameworks/cairo.framework/unix/include/cairo \
> --with-cairo-libs=/Library/Frameworks/cairo.framework/unix/lib \
> --with-cairo-ldflags="-lcairo" \
> --with-freetype \
> --with-freetype-includes="/Library/Frameworks/FreeType.framework/unix/include/freetype2 /Library/Frameworks/FreeType.framework/unix/include/ /opt/X11/include/" \
> --with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib \
> --with-geos=/Library/Frameworks/GEOS.framework/Versions/3/unix/bin/geos-config \
> --with-sqlite \
> --with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib \
> --with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include \
> --with-macosx-archs="i386 x86_64"
> # run before compilation: export VERSIONER_PYTHON_PREFER_32_BIT=yes
> PATH="/Library/Frameworks/PROJ.framework/Versions/4/Programs:$PATH"
> export PATH
> wxPython carbon 3 has issues - use 2.8
> Helena Mitasova
> Professor at the Department of Marine,
> Earth, and Atmospheric Sciences
> and Center for Geospatial Analytics
> North Carolina State University
> Raleigh, NC 27695-8208
> hmitaso at ncsu.edu
> http://geospatial.ncsu.edu/osgeorel/
> "All electronic mail messages in connection with State business which are sent to or received by this account are subject to the NC Public Records Law and may be disclosed to third parties.”
> On Dec 30, 2014, at 2:51 PM, Michael Barton wrote:
>> Has anyone yet tried to compile GRASS 7 on Mac Yosemite (AKA OS X 10.10)?
>> I will update soon and try it. It would be nice to know if it compiles without any issues.
>> Michael
>> C. Michael Barton
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
