[GRASS-dev] GSoC ideas - vector legend, medial axis
Anna Petrášová kratochanna at gmail.com
Thu Feb 20 13:47:28 PST 2014
On Thu, Feb 20, 2014 at 4:06 PM, Markus Metz
<markus.metz.giswork at gmail.com>wrote:
> On Thu, Feb 20, 2014 at 9:08 AM, Tereza Fiedlerová
> <tfiedlerova at gmail.com> wrote:
> > Hello,
> > I'm thinking about participating in GSoC this year, if I find some
> > interesting topic. I went through GRASS GSoC ideas. The two most
> interesting
> > for me are Vector legend and Extracting the medial axis of polygon. I
> would
> > appreciate if anyone can give me more information to these topics.
> > The first one is maybe described enough and I just need to study that
> more
> > to understand it better, but still anything more regarding that would be
> > appreciated.
> > The medial axis is not really clear to me. I know what is medial axis,
> but I
> > would like to know more about desired results. How it should be
> integrated
> > to GRASS (some new module?). Is it necessary to write it in C (why not
> > python)? Should the result algorithm extract the exact medial axis or the
> > approximation? ...
> A good approximation would be fine. It would be necessary to write in
> C for efficiency reasons and because C library functions need to be
> heavily used. Additionally, search structures like balanced binary
> search trees and min heaps are needed which are already implemented in
> GRASS as C code. I have already written 2 different C modules trying
> to extract the medial axis, both are incredibly complex and none of
> them works properly. I am familiar with GRASS, C, and Python and like
> to use the easiest approach. In this case I am pretty sure that the
> easiest and most appropriate approach is using C, not Python.
> Therefore I would recommend a good knowledge of C and some knowledge
> of the GRASS C API for this project.
> Markus M
Just in case it would be useful (at least for Tereza, it's mostly in Czech):
http://web.natur.cuni.cz/~bayertom/Adk/adk7.pdf
this is a presentation on straight skeleton algorithm (if medial axis is
the same or at least related?).
Anna
> > And one more question. Is any of these topics suitable for me if I am not
> > experienced in GRASS at all?
> > Thank you
> > Tereza Fiedlerová
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140220/d216d74d/attachment.html>
